Results 1 to 10 of 10
Thread: how come my SB Audigy is skipping?
    Low Bitrate ketchup318's Avatar
    Jan 2005
    Monterey Park, CA
    i just did a clean install of my carputer and i've noticed that when playing music, my audigy skips (or hiccups) when there is a sudden CPU load. I have everything up to date, has anyone else experienced this? thanks
    AMD 1700 & Abit VA-10 w/ 512Mb PC3200 Corsair Ram
    60GB 7200rpm HD - Opus 150W PS - Lilliput 7" TS
    Panasonic Slot DVD - SD Audigy NX 2
    Phoenix Gold 5.1 MT Amp - 2 USB Hubs
    Hauppauge WinTv USB2 - Holux GPS - Belkin Bluetooth
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Search for PCI latency
    Jan 2005
    Monterey Park, CA
    no it's USB, and it is directly connected to the motherboards USB port, no hubs or anything.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by ketchup318
    Oh... a USB model
    And you say that you've got the latest drivers for your motherboard/soundcard/videocard? Then I don't know
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    simple, usb relies a good deal on the cpu. start transferring a large file to or from a usb drive and do any heavy computing (say rendering some 3d work or encoding a video). youll notice that the transfer will quickly slow down. this is hy your audigy will skip.
    Your everyday carpc geek and tech guru at your service. *bow*
    May 2005
    i guarantee you that it is caused by your onboard video. this is why you should get a real computer without onboard video and use an agp card plus a pci soundcard. onboard video sucks, especially when combined with soundblaster products.
    Jul 2004
    Berkeley, CA
    Oh yeh... make sure to the the SB on its own USB port or on a USB 2 only hub. If you plug in any USB 1 devices, all the USB drops to USB 1 speeds.
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    I have this problem. I have the USB audigy connected to its own USB 2.0 port. I have urm, let me count, several USB devices.
    1. Griffin powermate
    2. USB LAN dongle.
    3. USB 2.0 Hub for the rest of the following...
    4. Keyboard (sometimes)
    5. Mini number keypad
    6. USB touchscreen interface for xenarc screen.
    I HAD a USB IDE drive converter connected up, to a DVD rom but it SUCKED.
    So, you see I have found the best way to hook it all up, with an INCREDIBLE amount of trial and error, and alot of friggin around, and put up with the rest.
    The skipping only happens about 3 times while listening to about 10 songs, so it doesnt really bother me that much. Don't think there is much you can do about it.
    On the other hand, if anyone knows something else that will help, shoot!!
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
    Jan 2005
    Warren, Ohio, USA
    try an add-on usb controller dedicated to the sound card?
    Nov 2001
    brisbane
    like what?
  1. SB Audigy 2 NX or Live 24-Bit External
    By Berg997 in forum General Hardware Discussion
    Last Post: 05-17-2005, 02:13 PM
  2. 5v power to USB SB Audigy 2 NX
    By shillier in forum Newbie
    Last Post: 05-04-2005, 05:25 PM
  3. SB Audigy 2ZS & EPIA
    By toxsickcity in forum General Hardware Discussion
    Last Post: 04-08-2005, 07:28 PM
  4. SB Audigy Sound Quality
    By titaniumkingpin in forum Car Audio
    Last Post: 02-19-2005, 09:40 AM
  5. Replies: 0
    Last Post: 08-28-2004, 03:14 PM
