Results 1 to 2 of 2
Thread: Com Port Amp Trigger
    FLAC mbkowns's Avatar
    Mar 2004
    I want to make a simple program that on startup it will short some pints on the com port and stay shorted which will trigger a relay which will then turn the remote wire on to my two amps and this will allow me to avoid the amp pop. I know there are boards that do this with relays usb com etc but I only need one relay and doing it this way it would be basicly free...
    let me know of somestuff that might help I look around a bit but maybe someone can give me some help here
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    MBK (AIM = IllMBKllI)
    Constant Bitrate emdzey01's Avatar
    Jan 2005
    san fernando valley
    haven't you tried to ??? it's already been done. you're talking about the com port's dtr (data terminal ready) pin. you wire that to your amp. you download a program that gives the dtr signal after bootup.
    search for "windows service dtr".
    Brushed Metal for Centrafuse 1.4
    Brushed Aluminum for Centrafuse 1.4
    xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  3. Amp turn on when audio signal is present
    By nrls2000 in forum Car Audio
    Last Post: 10-22-2004, 07:05 PM
  4. Opus remote trigger. Amp turn on
    By live2themaxuk in forum General Hardware Discussion
    Last Post: 09-08-2004, 04:37 PM
  5. Running remote signal to amp from parallell or serial port?
    By in forum General Hardware Discussion
    Last Post: 01-08-2004, 04:30 AM
