Results 1 to 10 of 10
Thread: Gathering Ideas . . . Disconnect plug for Opus power
    FLAC J187's Avatar
    Nov 2004
    Boston
    My Opus is mounted to the same board as my mobo. I want to make it so that I can easily take the whole thing out of my trunk when I want to. So, what I need to do is wire my opus to my car with a plug that can been easily be disconnected. I will be grounding to the chassis, using my remote turn on wire from my amps as the ignition wire, and running the power 12v to the power distro block for my amps. Does any have any suggestions as to what sort of plug I can use. I intended to use 8 awg power wires from the opus wire to the block and to the ground. Obviously I'm not gonna find a 14 (stock opus???) awg to 8 awg plug.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    May 2004
    I was thinking of.. 3.5mm Jack plugs.. but seeing my electrical skill isnt up to par, I have no idea if thats a good idea, considering 12v passing through jack plugs..
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    nooo! dont run that kind of power through 3.5mm plugs! unless you want to let out the puff of magic smoke
    as far as plugs go, something like these would work good
    肚子笑痛了
    S60 Install
    Tainted Love Cris's Avatar
    Romania
    3.5mm jack...
    Why don't you jack the Opus connector and plug in a 10AWG wire, as the 8AWG won't fit as it's too thick.
    May 2004
    lol, like I said, my electrical skill isnt up to par..
    Didn't think it would work Although for sound.. it does.. then again thats a gimme.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Be carefuk when using any type of pin/socket conenctor (like HDD molex ones) as when the sockets open up the connection is poor and you get a high resistance and thus heat etc etc.
    I have a lot of experience with melted connectors from my RC car days and I can recomend the Anderson Power Products single pole connectors. You can make them up into blocks of as many connectors you want in various shapes as they clip together and they come in various colours and power ratings. YOu can also create a keyed setup to prevent any wrong connections.
    http://www.andersonpower.com/index.html
    they are a curved blade that is pushed in contact with a spring. As long as you put them together right they work very well. Just make sure you get one big enough for the wire you use.
    EDIT: you can find these connectors at lots of places including model shops and Radio Spares.
    EDIT2: you want the 'Powerpole' series. eg http://www.andersonpower.com/products/pp/pp.html
    or the locking type (dunno what the locking bit means)
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hmm, would a computer PSU style connector be OK too? I guess there shouldnt be problem as it would handle enough current, it should be strong enough and durable, and it wouldnt allow a mis-connection
    FLAC J187's Avatar
    Nov 2004
    Boston
    Right on, Scouse that was the answer I was looking for. Thanks to everyone else for suggestios.
    Please help.
    Mar 2004
    Bristol
    I win
    n/p dude. been wonderign who made those things, made me go out and look. good connectors.
    Maximum Bitrate DeltaFX's Avatar
    France
    Maybe a neutrik-speakon-like connector ? If you use a standard psu connector, someday someone will plug your comp to the wall
  1. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  2. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 02:36 AM
  3. auto power on ideas?!?!?
    By detz in forum General Hardware Discussion
    Last Post: 08-07-2002, 12:19 AM
  4. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 05:27 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 09:33 AM
