there are guys here from sweeden ... they seem to do ok.
anyone live in minnesota or similar climate?
how has your car pc handled the extremes? i know nothing wants to work to well outside when its -30F or 90F
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
I live in coon rapids, and took many trips to the Iron Rnage during the winter.
LCD - faired fine but didn't like to turn on sometimes
HD - Didn't like to spin up right away, but that was with a 60W PSU, I now use a 90W so maybe that will fix it.
Other than that things worked fine. I'm finding more issues with the heat than cold right now. I have 3 case fans right now and it still get really hot.
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
Haven't had a problem. Although, I let the car warm up for a bit first. If I'm shivering, I'm too cold to enjoy music! LCD is a bit dim when it's below freezing, but that goes away quickly as I have it positioned near a vent. HDD = no problems.
Warm weather, otoh, has caused my (1st gen) computer to crash on long drives down to Mankato (2hrs). Easily solved by turning on the A/C.
So, just use common sense. If it's too cold/hot for you or your car, then it's too cold/hot for your computer. Start the engine and wait a couple minutes for things to moderate.
Oh - thinking about having a meet early next month. Check the Gatherings thread if you're interested...
yeah i am prom mn and its been ok for me
lcd is a bit dim at first but no other problems. like neon_eddy said, heat is more of an issue.
System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
Progress: Installation: 90% Dash fabrication: 80%
Parts Needed: USB GPS
Mine works fine from Duluth,Mn to Iron Range. But I have a garage for wintertime.
Eipa VIA MII 12000,160 gig HD,265 Ram,Tview 7.5inch Touchscreen,Holux 210 GPS USB,Mappoint 2005,RoadRunner,Motorola Wifi G,
I had terrible trouble last winter
Below 40°F hard drive would keep clicking and pc would reboot about 3 times before it was warm enough to actually boot up.
Below 10°F the hard drive would just click and it would not even boot past bios.
I took the fan off the board and wrapped hard drive up for winter worked ok until about 25°F next year hope to have full box built and it should keep it jsut warm enough, as before it was sjut open air in trunk. it is also a 3.5" drive so 2.5 might work better in cold temps.
Toyota Prius w/ NAV system and a 30gb Ipod :)it never crashes and always boots up.
