Results 1 to 4 of 4
Thread: 50pin help
    May 2005
    50pin help
    I just put my smil dvd rom in my glove box. now my question is where can i buy a SLIM 50pin ide wire cuze my pc is in the trunk or is there any converter from SLIM 50pin ide to usb ?
    Elsewhere
    Quote Originally Posted by russian_mafia
    You need the laptop -> IDE adapter , then an IDE -> USB adapter.
    Another option is to get a USB enclosure for a slim laptop such as this .
    How about the Wiki?
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you can also buy USB to IDE adapters that have both normal AND slim connectors on them (on opposite sides) which would probably be the simplest solution.
    check ebay.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Low Bitrate crazymadbastard's Avatar
    Jan 2005
    Connecticut
    Quote Originally Posted by evandude
    check ebay.
    The slim dvd drive would not plug into that. So you would still need a slim optical to 40 pin adapter.
    Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
  1. Converting 50pin slim cd to 44pin laptop hd
    By Kalus in forum General Hardware Discussion
    Last Post: 10-19-2003, 05:57 AM
  2. Slim-Slot-DVD Solved
    By vickumar in forum General Hardware Discussion
    Last Post: 08-21-2003, 02:27 PM
  3. WTB: 50pin LCD Controller
    By claylong in forum Classified Archive
    Last Post: 01-21-2003, 08:56 AM
  4. 50pin connector?
    By bradf0rd in forum LCD/Display
    Last Post: 07-31-2002, 05:02 AM
  5. Wiring Goldstar LCA4VE01A to 50pin Sage Controller
    By Squeeky in forum LCD/Display
    Last Post: 05-30-2001, 02:11 PM
