Results 1 to 4 of 4
Thread: Connecting Drives
    Feb 2005
    Connecting Drives
    Hi guys,
    Scuse me for a sec.. Getting my nomex overalls on. Ok. This has probably been asked before or probably seem dead simple. Anyway, how would I go about connecting 5.25" drives mounted on my dashboard to an ATX pc situated elsewhere. Are there any long (X >> 5m) UDMA/IDE cables? Will they need to be shielded?
    I realise that you could use a long USB cable and a USB adaptor to hook up say a slot DVD drive but is there anyway that I could mount the drive and use it connected to UDMA/IDE on the mobo?
    Malaysia
    -Alfa Romeo Giulietta 1982 with 1992 Alfa 75 2.0 Twin Spark Engine-
    Feb 2005
    Ok.. saw in the MP3 Store that theres an adaptor to make the slot dvd drive work on IDE.
    Still, can I find long IDE/UDMA cables?
    Malaysia
    FLAC evandude's Avatar
    Mar 2005
    Maine
    specifications for communications protocol generally include maximum cable lengths. maximum cable length for IDE, IIRC, is something on the order of 3 or 4 feet. Even if you got long enough cables, you may have trouble with the drives... they may have lots of read errors and such, and as a result go very slow, or they may just not work at all. Especially considering the electrical noise present in a car... and especially at 5m length, which is about 5 times longer than the longest IDE cables you can normally buy. If you really want to do it, go buy 5m of 40-conductor ribbon cable and two crimp-on 40-pin IDE connectors. All you have to do is put the connector in the vise, slip the cable in, and close the vise to crimp it; very easy. But like I said, it's at your own risk.
    Your best bet BY FAR is to just buy a USB-IDE adapter and run USB back to the computer, since USB cables work at much longer lengths. Not to mention, running a single USB cable to the computer is a lot easier than running one 40-conductor ribbon cable for each drive.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Feb 2005
    Evan,
    Thanks for the feedback mate. So does that mean that you guys who are running ATX boards out in the boot either have your drives in the boot, or use a USB lead to power the drive up front on the dashboard?
    Malaysia
  1. suspension for drives in car pc
    By fuctup in forum Fabrication
    Last Post: 06-02-2005, 07:38 AM
  2. Solid State Hard Drives
    By neon_eddy in forum Hardware Development
    Last Post: 04-12-2005, 01:02 AM
  3. FS: 704MB IDE Solid State Drives
    By dj2fast in forum Classified Archive
    Last Post: 05-09-2004, 04:19 PM
  4. For Truck PC: Use 2 old hard drives or 1 new one?
    By prerunnerv6 in forum General Hardware Discussion
    Last Post: 11-11-2002, 10:26 PM
  5. Connecting Laptop Hard drives to PC Mobo
    By CarMP3 in forum General Hardware Discussion
    Last Post: 09-24-1999, 05:06 AM
