Results 1 to 4 of 4
Thread: Should I keep my case fans off the opus?
    FLAC J187's Avatar
    Nov 2004
    Boston
    Probably has been asked, but didn't come up right away on my searches. Could someone just simply advise me whether or not to wire my case fans directly to the vehicle to spare the Opus' power or is there something wrong with that and should I run them off the Opus. 2 80mm Case fans in a vanity panel. Thanks
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    hmm.. I never though of using the unfiltered 12v .. but Ithink I'll do it too..
    as long as the power stay seperated it shoudl be fine.. and if it burns a fan.. big deal.. theya re cheap .. I see no adverse effects.. only good things.. then the PSU uses less juice..and makes less heat..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Elsewhere
    Quote Originally Posted by neon_eddy
    Make sure of the fan foltage.
    5v may be sufficient for 80mm fans...
    Less airflow would also make for a quieter install.....
    How about the Wiki?
    Nov 2004
    Ham Lake, MN
    I dunno about quiter.. for a quiter ride I would first need to get ride of road noise, engine noise, and with music going.. who can hear case fans.. under a seat or in the trunk.
    Shawn
  1. Opus outside computer case OK or not?
    By -zip- in forum Power Supplies
    Last Post: 05-05-2005, 02:14 AM
  2. Opus 150w PS & Xenarc 7" Shroud (case)
    By GTC in forum Classified Archive
    Last Post: 02-15-2005, 04:26 PM
  3. Best case for 90w Opus.
    By Nico3k in forum General Hardware Discussion
    Last Post: 11-24-2004, 10:33 PM
  4. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  5. What case fits the 150W opus pcb
    By migrane in forum Power Supplies
    Last Post: 05-21-2004, 11:16 AM
