Results 1 to 6 of 6
Thread: No Ethernet Connection on EPIA-M board
    Jun 2005
    Any help greatly accepted!
    Just received what should become a carputer and everything works well except for an ethernet connection to my home LAN. When I go to Network Connections, the 1394 connection shows up, but nothing for a local area connections. In System > Device Manager > Network Adapters, I only see the 1394 Adapter and nothing else.
    When the CAT5 is plugged into the RJ45 on the rear, both the green and amber LEDs light. Do an IPCONFIG and nothing shows up.
    What do I need do to get the LAN adapter loaded up? I've tried to install new hardware and anything to get it loaded, but no joy.
    Any help greatly appreciated!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Did you look in the BIOS?
    Raw Wave
    Jun 2004
    On the beach
    As Laidback says, sounds as if the LAN adapter is disabled in the BIOS.
    Jun 2005
    My thanks to you both! I did look at the BIOS (at least, in the VIA manual), but didn't see the "enable onboard LAN support." It works like a champ!
    Eric
    May 2005
    Go to Device Manager to see if there is a question mark on the network adapter. If it is there, that means the driver did not install correctly.
    Elsewhere
    Quote Originally Posted by uhoja
    Why are you posting this 'solution', when the person with the original problem posted that he resolved the issue?
    Read the ENTIRE thread before posting next time, n00b....
    How about the Wiki?
  1. Epia board fried
    By BigToach in forum General Hardware Discussion
    Last Post: 10-13-2004, 11:11 PM
  2. WTB(or trade): Epia 9000 or 10000
    By kovan in forum Classified Archive
    Last Post: 05-05-2004, 10:48 PM
  3. epia board & "nonstandard hardware"
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 09-04-2002, 12:40 PM
  4. c3 800mhz, via epia board, and divx
    Last Post: 08-28-2002, 10:57 PM
  5. PS emulation with the c3 800mhz, via epia board ???
    By zzsprade in forum General Hardware Discussion
    Last Post: 07-10-2002, 01:03 AM
