bump.
I Have a firewire/USB controller.. and some how the firewire part doesn't work. USB is still fine.
I noticed on the PCB that there is a component that shows signs of getting a bit too hot, some scorching.
I use the controller to power my screen, and it had a weka ground and I think it used the controller via firewire as a ground path. so I;m thinking of replacing the burned part and hoping for the best.
I have attached a photo of the component highlighted.. any one know what it is?..
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
bump.
Shawn
crystal i think.
check your firewire connectors for shorts (inside the connector and where they solder to thw board)
what is that jumper below the one with 2 wires already in? (on the left). could that need power to enable the firewire?
Yeah, that's a crystal. And also, Firewire (6-pin) has power on it, so I don't think the ground would cause a problem...
well I tried connecting it to my laptop and no dice.. I connected my laptop to the PC and I got connected that way..
is that (crystal) easily obtainable and or capable of burning up?..
Shawn
