Results 1 to 4 of 4
Thread: USB 2.0 or 1.1 devices?
    Dec 2004
    Sweden
    How do you know what speed a USB device is using? I have the following devices I need to attach; GPS-mouse, touch controller, DVD-rom drive and an Audigy card. I guess the GPS and touch is 1.1 devices and will slow down everything at that hub, but how can I check for sure?
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Im fairly sure that plugging a 1.1 device into a 2.0 hub does not slow down the bus. It will offer a connection to those devices at 12mbps max and the rest at 480mbps max
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    you can mix and match USB devices on USB2.0 and even if you had just a 1.1 port those should coexist, with a slight speed issue on the DVD drive, and maybe, the sound card
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Quote Originally Posted by aoLhaTer
    Quote Originally Posted by Hcomplyr
    That's not exactly true. It depends on the type of hub you are using. The hubs that allow simultaneous USB 1.1 & 2.0 connections are called MultiTT hubs. They are hard to find and don't say it anywhere on the packaging.
    Also, it depends on your USB controller. Some controllers don't allow mixing and matching different speed devices. So you have to connect 1.1 devices to one controller (a controller on your mobo typically has two USB plugs) and 2.0 devices to another controller.
    I created a thread for this. Do a search under my name and you will find it. I included a link to a good article on THC about these types of hubs.
  1. USB Devices = Always On??
    By KingsDude in forum Newbie
    Last Post: 02-22-2005, 05:38 PM
  2. How finicky are your USB devices?
    By judoGTI in forum General Hardware Discussion
    Last Post: 10-01-2004, 03:35 PM
  3. USB 2.0 PCMCIA Card
    By Rith in forum Newbie
    Last Post: 06-13-2004, 12:55 PM
  4. Wireless and USB 2.0 cards
    By Defiler in forum Classified Archive
    Last Post: 04-07-2004, 09:59 AM
  5. powering some usb devices
    By cubanmoses in forum General Hardware Discussion
    Last Post: 10-08-2003, 12:23 PM
