Results 1 to 9 of 9
Thread: My carputer won't turn on (MB or power supply??)
    Jun 2000
    NYC
    Hi. I currently use a Book PC 500 mhz i810 for my setup.
    I'm trying to determine whether I fried the power supply or the motherboard. Anyone know a quick way of finding out.
    I turned my carputer on the other day, drove to the gas station, turned it off. When I hit power, it would no longer have any response, no fans,nothing.
    I would try swapping the power supply, but I don't have a spare micro atx power supply.
    Thanks for any suggestions.
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by mykolJay
    Then you won't know, will you.
    Test it with an ATX PSU, and see.
    You could also try with a multimetre, and see if power comes out of the PSU.
    May 2005
    Austin, TX
    If absolutely nothing comes on, fans, LEDs, etc, I'd guess it's the power supply. If you hook up a power supply to a bare motherboard, even without a CPU, the power supply fan will at least spin. Might crack open the power supply and see if there is a fuse in there. A multimeter in the power supply will tell you if it's failing or not as well....Just dont short any leads and let the smoke out!
    cent
    Jun 2000
    NYC
    Quote Originally Posted by Cris
    So atx power supplies have the same outputs.
    Good idea with the multimeter, i'll try that as well when i get home tonight.
    Also, on a side note, i posted in for sale forum, but dows anyone have an extra micro-atx power supply they want to sell or trade (or give me)? Or does anyone know where to get one for really cheap? Thanks all.
    Romania
    ATX is the standard, in terms of connectors and the wires that go into it, not its size.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    - Pull Drives power connector out and the main ATX power connector out.
    - Short pin 13 and 14 on the ATX connector to see if the PSU turn on.
    - If not, the PSU is likely going SOUTH.
    - If it turn on, the problem could be somewhere on the mobo. Make sure to check the output voltage on all rail to see if the PSU out put within Spec (10% I think).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jun 2000
    NYC
    Quote Originally Posted by MatrixPC
    pardon my ignorance.. but how do u short a pin??
    Romania
    pardon my ignorance.. but how do u short a bin??
    Connect them!
    Sep 2003
    Beach City, Socal
    Use metal paper clip and connect the 2 together. Just make sure that "paper clip" doesn't touch the mobo or any sensitive parts.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  3. AT power supply voltages for MB
    By MoparChris in forum Power Supplies
    Last Post: 10-29-2003, 12:16 AM
  4. What is the ultimate carputer power supply??
    By THEMP3KID in forum Power Supplies
    Last Post: 02-15-2002, 06:34 AM
  5. power supply questions. + Schematic
    By Raas in forum Power Supplies
    Last Post: 10-31-2001, 01:02 PM
