Page 1 of 6 123456 LastLast
Results 1 to 10 of 52
Thread: Pentium M CPU on a regular Socket 478 Mobo?
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    I was looking for a low power system and found a pentium m cpu for cheap. Its a socket 478 just like a regular pentium 4 and celeron cpu are, but will it fit on a regular socket 478 mobo just like the p4 and celerons do? or will i need to modify the pins or anything? On intel's site, it says Mobile CPUs have 478 pins, but everywhere else it says 479?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Is that a p4 mobile CPU or an actual M CPU? Because the mobile P4's are 478 pins, the M's have the extra pin to keep you from using it on a normal board, but they already have an adapter, I will see if I can find the one I was looking at.
    肚子笑痛了
    S60 Install
    Elsewhere
    Quote Originally Posted by CJ8501
    It won't work, even if the pinouts are the same.
    ASUS makes an adapter that will allow it to work in certain ASUS motherboards. Check their website for details.
    How about the Wiki?
    May 2003
    Miami, FL
    well the P4 mobile CPU will work on a normal board, I have one. But the M will not work without the special adapter
    肚子笑痛了
    S60 Install
    Jul 2004
    Orland Park, IL
    O so theres a difference between Pentium M and Pentium Mobile? Did not know that... I was looking at a Pentium Mobile CPU... I thought they were the same
    May 2003
    Miami, FL
    yup, but I am going to end up using my mobile P4 because it fits a normal board and uses less power than a normal P4, but the chips are much higher quality than a desktop CPU because intel goes and picks only the best of the die to make the mobile chips. So in turn they are higher performance than other chips that are the same speed.
    肚子笑痛了
    S60 Install
    Nov 2004
    Cali
    No, there is not. There is a difference between Petium 4 Mobile and Pentium M, that's what jcdillin was talking about. Refer to Darque's post for the rest.
    I have found you an argument; I am not obliged to find you an understanding.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    Dont bother with a Penitum M, get a P4 mobile, mines been treating me great, and was only around $27 on ebay including shipping
    PC Components:
    My work log
    Newbie White 350z's Avatar
    Jun 2005
    Arkansas
    I'm confused. What exactly is the difference in the Pentium Mobile and the Pentium 4 M?
    CarPC Status
    [|---------] 10% Complete
    Home Rig -
    Athlon 64 (939) 3200+ (Watercooled)
    DFI NF4 SLI-D Mobo
    Gigabyte 6600 128MB PCI-E Video Card
    (4) 9GB U160 SCSI HDDs in 36GB Raid 0 Array
    160GB Seagate S-ATA Drive w/NCQ
    Dell 20.1" Widescreen LCD
    Jun 2005
    Arkansas
    Okay, I think I've figured out the difference. The Pentium Mobile is the Banias/Dothan cores, a true "Pentium M," whereas the old mobile processors were Pentium 4's designed to be mobile, hence the "M".
    I've searched for the stuff below, but need a little help still.
    So, that being said, I want to pick up an old Pentium 4-M processor. How do I know what I am getting? I've been looking on ebay, but am I coming up with the right stuff? Here's a link to one:
    http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
    Also, what boards will run the old pentium 4-m's? Will any socket 478 board run them just fine?
    Thanks!
    CarPC Status
    Home Rig -
    DFI NF4 SLI-D Mobo
  1. WTB: Pentium 4 CPU socket 478
    By Rundell in forum Classified Archive
    Last Post: 06-05-2005, 03:48 PM
  2. mobo/ Pentium III processor question
    By AUskier in forum Newbie
    Last Post: 02-11-2005, 04:39 AM
  3. Mobo, CPU and power rail
    By MatrixPC in forum General Hardware Discussion
    Last Post: 11-15-2004, 10:19 AM
  4. FS: mobo, power supply, CPU etc just look!
    By dannn in forum Classified Archive
    Last Post: 11-01-2004, 10:52 PM
  5. Brand New Mobo and 2.53 Celeron CPU
    By CJ8501 in forum Classified Archive
    Last Post: 09-30-2004, 08:16 PM
