Results 1 to 9 of 9
Thread: 1997 Honda Civic CD Changer Help!
    Jun 2005
    Folks,
    I have a 1997 honda civic with a cd changer HU. The changer is missing but the plug and bracket is still there.
    It is my understanding that older alpine changers will work with this plugin but may have the audio swapped.
    What I want is the pin out for the 1997 civic changer output and the pin in for the 5960 Alpine changer I have to see how compatible it is. I've searched this message board and the web with no luck. I know there are honda to alpine converter cables but I want to first verify that the pins from the honda are o.k. When I plug the changer in I get nothing and when I test the honda-side din, I get no power showing up.
    Help? I think if I had both din pin outs I could work it out.
    Gooch
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you for Alpine M-BUS and/or Honda M-Bus, you may get some usefull info.
    If I remember it right and you have the one with DIN style connector, the plug different is pin4 and pin2 are swap (audio L=R and R=L).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jun 2005
    97 civic alpine changer
    Yes I think you are right. I understand that the audio might be flipped. I'm still trying to find a pinout of those two (honda and alpine cd changer) connections. I googled on them and found a lot of adapters but no pin diagrams.
    I'll keep looking. I know some are on the web.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I have got one around here somewhere. I had a 98 civic with an alpine changer, I actually still have the changer if you would like to buy it.
    The cables are fairly cheap <$10, that is how I created my aux in.
    Edit, found it!
    Sep 2003
    Beach City, Socal
    Not Honda but Acura (well what the hell )
    http://www.nsxprime.com/FAQ/DIY/sound_system.htm
    The image below is also from the url above (from Alpine CDC side)
    Note: The image need 180 degree turn to match the one from the above post.
    Jun 2005
    thanks guys
    Thanks for the help all. I did take a look at it last night and did some tracing with my meter and found there was no hot leads from the honda side so I got curious and pulled the radio. For whatever reason, the cable was pulled out of the back of the Head Unit so I reconnected it and it now controls the changer fine. Sounds good too. I will have to check into the left/right swap that y'all mentioned with the honda/alpine mbus connection, but its going now anyway.
    Thanks again for the help with the pin outs. Now I will have to try
    something hard down the road: hooking an mp3 player up like you guys do
    thanks
    Gooch
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    MatrixPC, I googled to hell the pinout for Honda to Alpine MBus and couldn't find a real pinout, just pin 2&4. THANK YOU!!!!!!!!
    Newbie shiboilee309's Avatar
    Aug 2005
    CA
    just go and get a new alpine deck to make it easy for you...
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    i think they make an adapter... check crutchfield.com
    Carputer status: [-*---------]
    Im thinking laptop...
  1. Connect external audio source to Clarion unit via cd changer plug
    By vpapanik in forum General Hardware Discussion
    Last Post: 09-21-2005, 06:55 PM
  2. CD Changer Cutting Out
    By ClubFed11 in forum General MP3Car Discussion
    Last Post: 03-15-2005, 05:43 PM
  3. running stereo audio to rf cd changer input
    By wh00ps in forum Car Audio
    Last Post: 02-27-2005, 11:01 PM
  4. FOR SALE - ICE - Clarion Top End Mini Disc & CD changer
    By Paul_GPvR in forum Classified Archive
    Last Post: 01-21-2005, 06:28 AM
  5. 1994 Honda Accord CD Changer In to Aux In?
    By dynamike in forum General Hardware Discussion
    Last Post: 01-16-2002, 04:17 AM
