Results 1 to 10 of 11
Thread: USB Hub - Powered or non powered?
    FLAC J187's Avatar
    Nov 2004
    Boston
    Is there really a good reason to run a self powered USB hub instead of a bus powered in a car pc environment? To the best of my knowledge, I am not running out of OPUS power anytime soon. Is it ok to use the unregulated voltage of my car directly to power a powered USB Hub. I'd say no more than 4 devices will be run off it.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Powering the USB hub through an LM 12V regulator will be better than using a non-powered hub. There is only so much power the USB bus can provide.
    The more power you can conserve from your DC PSU the better.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Now, if I buy a self powered, will it power from the bus if it's not plugged in? Or do I have to power it externally at all times?
    Please help.
    Feb 2005
    Quote Originally Posted by J187
    I believe a powered hub that has no power on will use 5V from the USB bus.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Sweet. Thanks. Guess I'll grit my teeth and pony up the extra dough.
    Please help.
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Yeah, self powered is what I have (Well, it can do both, but I leave the switch set on self powered). It just takes 5 volts from the USB bus to power itself, really is a lot easier.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Self powered will only yield 500mA
    Powered hubs will give 2A+
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    BUS-powered hubs that have no external power will only put out 100ma per port. For touchscreens, this is enough, for most other things it isn't. SELF-powered hubs that have external power put out the full 500ma per port, which some devices need.
    It depends on what devices you have. Cameras, WiFi, need 500ma.
    Mar 2003
    Rohnert Park, CA
    Quote Originally Posted by Jahntassa
    125mA actually
    Raw Wave justintime's Avatar
    Apr 2005
    Will a USB GPS normally run off a regular BUS-powered port? (i.e., at 100 ma) ?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. Replies: 197
    Last Post: 06-15-2006, 08:47 PM
  2. Externally Powered USB Hubs and Car Power
    By chewiee in forum General Hardware Discussion
    Last Post: 03-20-2005, 10:55 AM
  3. Best USB Hub
    By nsmoller in forum Input Devices
    Last Post: 02-08-2005, 03:35 PM
  4. Internal USB Hub?
    By jrich523 in forum General Hardware Discussion
    Last Post: 07-07-2004, 07:44 AM
  5. Powering USB 2.0 Hub off HDD +5v Rail - Any problems?
    By sq_geek in forum Power Supplies
    Last Post: 06-07-2004, 09:11 PM
