Results 1 to 10 of 10
Thread: Relocating DVD Drive
    Jun 2005
    My current planned setup is as follows
    Silverstone SST-LC09 Case mounted in boot containing the following;
    • Nehemiah M10000
    • 512mb DDR
    • 120Gb Seagate barracuda 3.5"
    • Opus 90W power supply
    I will be using the gain 7" wide touchscreen flush-mounted in the dash. Will this be ok using a USB and VGA extension cable?
    Also I hope to use a slimline DVD drive below the screen. Is there a usb device I can use in a similar way to the screen? so run a USB extension from the boot to the dash to connect to a slimline drive and power it?
    Possibly this drive?
    Expansys link
    Are my needs within the capabilities of the 90w power supply?
    Thanks in advance.
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    No problems with extending the screen, I've done exactly what you described before with no problems.
    As far as the DVD drive goes, what you said would work. You could also buy an external enclosure such as this:
    http://www.newegg.com/Product/Produc...82E16817145314
    I have that exact enclosure, and it looks big, but inside, it really is just a USB to IDE adapter (and a small power supply to power the hard drive/CD-rom you have in it). If you gut it, it shouldn't take up much room.
    Good luck
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    But I bet you are going to use laptop DVD drive, right? In any case, there are USB - slimeline IDE enclosures available as well on the market.
    Jun 2005
    Nice one, I was concered that the VGA/USB cable might degrade quality over that distance to make it unuseable.
    Elsewhere
    Quote Originally Posted by andy@ukcars
    Get high-quality cables and this won't be an issue. Cheap, unshielded cables will encounter signal loss.
    How about the Wiki?
    Mar 2004
    Quote Originally Posted by RS3RS
    Good luck
    And what about power?? for the small power suply? in car
    Jun 2005
    Quote Originally Posted by mashina
    I'm not sure what you mean here. If you mean how is the DVD drive powered then it is powered from the USB.
    Low Bitrate madmartigan's Avatar
    May 2005
    Canada
    Quote Originally Posted by DarquePervert
    From a certifiable technician, you shouldnt go past 16 feet with USB cables if you can help it. HTH
    Jun 2005
    16 feet????? In a car who would need 16 feet of USB Cables....
    Jun 2005
    16 feet so approximately 5 metres. I have a 5m USB cable so should be more than enough i'd say.
  1. USB DVD drive not reading dics
    By 04scooby in forum General Hardware Discussion
    Last Post: 03-01-2008, 06:30 AM
  2. Playing Media Files off DVD Drive
    By Chita79 in forum FrodoPlayer
    Last Post: 10-29-2004, 04:25 PM
  3. WTB: Laptop DVD drive or IDE adaptor
    By Fosgate in forum Classified Archive
    Last Post: 10-24-2004, 02:32 AM
  4. DVD DRIVE Adaptor
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 03:15 PM
  5. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 08:06 PM
