Results 1 to 5 of 5
Thread: Looking for a Small IDE cable...
    Jun 2004
    AZ
    I cant seem to find a good store that has small or short ide cables. I got a 4in IDE cable that was rounded with a shuttle case. I used this cable in my new case and need another. Everyone just carries the standard 18" crap. What about us CarPC gurus using mini-itx cases? Can anyone point me in a good direction?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    JUst take one of the regulars (the one that comes with double connector) and cut the longest part and that it.... you will have 4 to 6 inches of ide cable
    Elsewhere
    Quote Originally Posted by jedi7001
    Use a standard ribbon cable and fold it over multiple times to achieve the length you need/want. Secure it with a zip tie.
    When I'm building a box, I tend to fold the IDE over the top of the hard drive to keep it out of the way. It also helps open up the case for airflow that way. Granted, that's a full ATX case, so it doesn't help you here.
    How about the Wiki?
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    Quote Originally Posted by thanatos106
    Yup, use a nice sharp craft knife and just keep the bit that usually goes between the drives (sometimes marked primary and secondary on the tabs).
    There is no special end, all the plugs and wiring are the same whatever end you use. From a standard 24" cable once you cut the end off that goes to the system board you should just have an 8" single ide piece.
    Nov 2004
    Quote Originally Posted by Mad Ad
    I think he got the point.....
  1. 2.5" IDE cable question...
    By SamDude in forum General Hardware Discussion
    Last Post: 01-13-2006, 05:49 PM
  2. How to extend an IDE cable??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 10-28-2003, 10:50 PM
  3. WTB: LONNGGG IDE Cable.
    By Mp3Goose_Your King in forum Classified Archive
    Last Post: 03-27-2003, 09:19 AM
  4. Replies: 0
    Last Post: 02-11-2003, 02:15 PM
  5. Where can I get 80 pin IDE cable?
    By jtk in forum General Hardware Discussion
    Last Post: 01-27-2003, 03:29 AM
