Results 1 to 10 of 11
Thread: Help or i'll DIE
    May 2005
    Question Help or i'll DIE
    First i want to say sorry for my english.
    i have so much problems with my carpc project that i even dont know with what to start.
    i spent a week trying to fix the problems.
    one of my problem is.
    i bught from mp3car a slim dvd drive and the adapter for it, now because my pc located in the trunk and the dvd rom in the front dash i diceded to buy that ide to usb 2.0 adapter. i did all the connections. when it came to installtion i use the network to install the drivers but some how it doesnt work it say you have to use high speed usb hub but i dont think its the problem why the dvd rom doesnt work. then it say an error acoured code No. 10 ???? my quastion is why the dvd rom even dont have a power it even wont turn on or do i have to connect other wires to the ide adapter ?
    plz help
    Tainted Love Cris's Avatar
    Romania
    I'm assuming you already connected it to a 5V line. Your problem might also be if you're using a non powered USB hub.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Your IDE cable might be upside down causing the drive to not power up. If it won't even eject, that's probably the problem.
    The USB 2.0 warning will come up every time you plug a USB 2.0 device into a non-USB2.0 port.
    Error 10 means the device isn't 'starting'. Try downloading the drivers to your system, then installing.
    May 2005
    what drivers? for the usb hub ? or the ide to usb adapter ?
    May 2005
    Cris what 5v line ? i just connected the long 40 pin thats it
    Romania
    Quote Originally Posted by russian_mafia
    You have to power the slim DVD drive from the 5V line from the PSU. It can't work if it isn't powered, can it...
    May 2005
    Cris can you show me where i have to connect in the adapter ?
    Romania
    On the back of the slim dvd unit there is a floppy style connector. Connect the floppy molex from the PSU in there and this way the slim DVD unit is powered. If you extend those wires, you'll only need the red one (5V) and the black one, right next to the red one (gnd for 5V). The yellow one is 12V and the one right next to the yellow one is the gnd for 12V. For a slim dvd, you'll only need the 5V lines.
    The connector in the left is the one I'm talking about.
    May 2005
    thanks alot man one more quastion do you know wich one of this 4 sticks is the 5v and the ground ?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    the 5v is the one closer to the ide connector and the ground the one next from the pic:
  1. My New Toy
    By lgbr in forum Off Topic
    Last Post: 07-05-2005, 04:43 PM
  2. Feeding my M1000 12.85V, will it die soon?
    By Grayscale in forum General Hardware Discussion
    Last Post: 10-21-2004, 03:41 PM
  3. Theory on why Lilliput touchscreens die
    By archimense in forum LCD/Display
    Last Post: 08-27-2004, 02:12 AM
  4. Battery power.
    By Mafri in forum General Hardware Discussion
    Last Post: 02-21-2003, 01:31 PM
  5. How does a hard drive just die?
    By Sleeka in forum General Hardware Discussion
    Last Post: 08-08-2002, 03:27 PM
