run any power lines separately, and use the cat5 for signal lines...
you also have to worry about signal quality... for instance, USB cables are shielded, and if you go running them through 8-conductor cat5 alongside other signals, things might not behave very well.
and... have fun making all the wiring harnesses to go from regular cables to cat5 and back... I've gotten quite sick of making similar ones (on a much smaller scale)... in the time it takes to make all the adapters you could have easily just run separate wires...
personally I think just disconnecting all the cables from the computer is easier anyway, and at least in my car, I can run a new wire pretty easily, so I don't consider it a big problem. but it all depends on the car, and personal preference...
LinkBack URL
About LinkBacks
