Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: thermoelectric cooler
    Low Bitrate odleon's Avatar
    Atlanta
    does any one have any ideas on how these could be used??
    http://www.allelectronics.com/cgi-bi...T-5&type=store
    Variable Bitrate egeekial's Avatar
    May 2004
    AKA peltier cooler. They're a ***** to power (especially in a car) and a ***** to cool.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i dont understand how it works
    PC Components:
    My work log
    May 2004
    http://en.wikipedia.org/wiki/Thermoelectric_cooling
    I'm not sure of the internals, but one side gets really hot and the other gets really cold.
    Atlanta
    it said on the page they where intended for 12v use. what would you need to power them??
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Quote Originally Posted by odleon
    Um...is this a trick question? 12 volts...
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    I would not recommend you use peltiers in carputer applications. First of all, it requires energy to move energy. The power draw on these things are killer: the peltier I've used in overclocking a desktop is a 6A draw at 12V. Secondly, all they do is maintain a temperature differential. So, in order to keep the cool side cool, you have to keep the hot side cooled (liquid cooling, etc). Fans attempt to bring temperatures down to ambient temps, peltiers actually pull heat out to create below-ambient temps. Since I don't see the need to create sub-zero temps in a car environment, I advice against peltiers.
    -psyrex
    Dec 2004
    Maryland
    from the site you linked egeekial,
    Methods that have been used to cool overclocked components include: forced convection (a fan blowing onto a surface); liquid cooling (liquid carries waste heat to a radiator, similar to how automobile engines are cooled); liquid nitrogen (perhaps the most dangerous method); dry ice; phase change cooling (as used in refrigerators); and submersion (placing the entire computer in an inert fluid). Liquid nitrogen is a temporary cooling measure in most cases, since a sufficient supply of power to maintain the LN2 coolant at liquid state is uneconomical. Because of this, liquid nitrogen (or dry ice, for that matter) is used as an extreme measure to set a record in a one-off experiment rather than to cool a system for a normal period of use. One reason is the cost of these extreme cooling methods, or usually because the hardware exposed to such cooling is ironically destroyed in the process. Of the aforementioned methods, air cooling, liquid cooling, and phase cooling are the most popular, due to their efficiency, availability, and affordability.
    interesting idea for cooling in the car, I recall seeing several exhibits of computers submerged in liquid.....if someone did this in the car, that would be very cool
    PC Components:
    My work log
    Dec 2004
    Maryland
    Quote Originally Posted by Change
    hes responding to egeekial
    PC Components:
    My work log
    Atlanta
    Quote Originally Posted by egeekial
    was refering to his comment. if thay are a ***** to power, how do you do it??
  1. FS: Speeze Socket A AMD Athlon XP CPU COOLER
    By jusatry in forum Classified Archive
    Last Post: 04-14-2005, 06:50 PM
  2. Has anyone used this HD cooler?
    By RogerWilco in forum General Hardware Discussion
    Last Post: 08-22-2004, 03:00 AM
  3. Heatpipe cooler for M10000
    By Seth in forum General Hardware Discussion
    Last Post: 07-12-2004, 08:24 PM
  4. FS: 2 80GB 7200rpm Hard Disk & Zalman CPU Cooler
    By ashbosh in forum Classified Archive
    Last Post: 05-24-2004, 11:10 AM
  5. wanted: Just Cooler RC-168 Computer Remote Control
    By churnopol in forum Classified Archive
    Last Post: 04-23-2003, 04:42 PM
