Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 99
Thread: Ampie Case information and pictures
  1. #11
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by Zip-Lock
    FYI, the OPUS 90 watt isn't made anymore, it's been replaced with the 120 watt.
    I must admit, I didn't know that...
    Neither of them will fit in this case so it really doesn't matter.
    No, I was wondering if the manufacturer makes, or could make a similar case in which the Opus could fit in. I know I'd get one. As I see it, this is an ideal case for a carpc, as the optical drive is usualy placed in the dash somewhere, and a PCI card is not always needed, thus keeping the case really compact.
  2. #12
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Thats a cool case, I like it
    Im all about small cases and there seems to be no wasted space there
    The Molex connector is a nice touch too
    Tad on the expensive side but still cheaper than a Travla
    Im lucky enough to have had a guy custom fab me a basic aluminum box for $50. Serves my needs (case isnt even seen)
  3. #13
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Awesome case! Love it.
  4. #14
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I received a sample of one of these cases a few weeks ago. It looks very solid and nice -- completely consistent with other car audio equipment. I'd switch over to it but it's a bit larger than my current C134 case so it won't fit in my storage cubby. IIRC, there is actually room to fit two 2.5" drives in there with a M10k.
  5. #15
    Registered User
    Jun 2005
    what about using one of those little square cases for lanners wouldnt' that work any better?
  6. #16
    Jun 2005
    THANKS! I just bought this case ( I must say its really solid) and appriciate the pics as there are zero instructions on how to set it up. I have the .PDF for the M1-ATX, that was pretty easy, but I do have a follow-up question. If you look at the pic you see there are connections to the M1, then the connector that goes to the car for power, notice there are more wires on the car connection then on the M1 connector. Where do these go? Is there a step by step instruction manual on this? Loose wires always make me nervous!
    Thanks!!
    -SnE
  7. #17
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    Kinda neat how it resembles an amp, although it would suck if a theif stole it thinking it WAS an amp lol...
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
  8. #18
    Aug 1999
    Washington D.C.
    Quote Originally Posted by sipneat
    Thanks!!
    -SnE
    The only wires that are required are the red, black, and white. Everything else is optional. Some of them aren't even connected on the other side.
  9. #19
    Aug 1999
    Washington D.C.
    Here's how it wires up:
    Wiring harness on inside of case:
    Red: + terminal on M1-ATX - constant 12V battery power
    White: ignition sense wire on M1-ATX (center terminal between black and red on M1-ATX)
    Black: Ground, - terminal on M1-ATX
    2 pin header (optional): can be connected to remote amp turn on, or remote switch.
    2 pin header from red case LED: connects to LED header on M1-ATX
    Wiring harness on outside of case:
    Red: 12V + connect to battery
    White: ignition switched, can be connected to an accessory wire (this tells the computer when it need to turn on or off)
    Thicker Black cable: Power ground
    Green: Not connected
    Thinner black cable: Not connected
    Orange on top: optional, may be used with amp enable or remote switch
    Orange on button: optional, may be used with amp enable or remote switch
  10. #20
    May 2005
    Does it come with a fan??? Its really weird but told me that the unit does not come with a fan (although up to 3 can be mounted.) I think mp3car ampie case DOES include ONE fann.. i m not sure.. Mods can you please confirm?>?
