So I can't use a motherboard like a ASUS A8N-VM CSM Micro ATX AMD Motherboard and using an athlon 64 cpu?
there are two orange wires. I have two amps. Would I hook an amp up to each? Or does one go to the remote wire and the other to both amps, inline?Originally Posted by Zip-Lock
1 is remote ground and is optional, the other is the remote positive which will turn your amp on. You can link one amp to the other but better check amp draw through the remote on your amp, though I would think it's very low current.Originally Posted by willisan
1999 Isuzu Trooper 3.0 Duty
Lilliput 8" Touch Screen
VoomPC Case
M1-ATX PSU
MII 12000 MoBo
512MB DDR
40Gb 2.5" Drive
so is there no way to get a regular sized (3.5) hard drive to fit in there?
ABIT VA-20 motherboard, AMD 1700+, 512mb RAM, 40gb HD, M1-ATX power supply, Lilliput 7" touchscreen
Will the M2-ATX PSU work in this case? Every reference I see here on the forum is to the M1-ATX, although several listings on e-bay discuss both PSU's as being compatible. I'm curious if anyone has tried a M2-ATX and whether or not it actually works. Would this be a superior PSU to the M1?
Thanks!
I had the same question as AllCammedUp. Every reference seems to mention the M1-ATX, and I really had my eye on the M2-ATX, I wonder if anyone has experience with the M2 and its reliability. I did notice the Opus in this tiny enclosure, Good Job Man.
The M2-ATX fits without any problems in this case.
the M2 is identically sized to the M1. Check my install in the signature for yet another ampie case (also known as VoomPC)
Current:
[BMW E46 ///M3 Convertible]
Previous:
[BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
I have one of these CF-to-IDE adapters: http://www.acscontrol.com/Index_ACS....CF_Adapter.htm
Can I coax this inside the case somewhere with an M2 PS, and 2.5" HDD?
Thanks,
BoB
I'm looking at doing the exact same thing. I've been thikning the only way to do this is to get a very very short cable (probably have to make it), and make the flexible ribbon rigid using some plastic plate or something. That way, the CF adaptor can be made to be parallel to the motherboard, so no vertical space is consumed.
Current:
Previous:
