Results 11 to 20 of 29
Thread: How to power 5V usb hub from 12v
  1. #11
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by spaceman
    Im not all that electronically minded, looks a bit confusing with all the different diagrams. Anyway i ordered some samples of it, so ill see how i get on when i receive them.
    Do these maintain a constant output, even with a varied input ( 12-14v)
    It really isn't that hard. WHen you get them, if you need help, just let us know.
    Yes, they will maintain the voltage even with a varied input, as long as it is above the threshold voltage. Basically, the input voltage has to be a certain amount above the output voltage. Usually it is about half a volt to a volt. You should have no problems getting clean, steady 5 volts in the car, since if the battery/alternator get anywhere near 5 volts, it wouldn't be working.
    Michael
  2. #12
    Oct 2004
    Glasgow, UK
    Thanks for all your help. I prob will have to get back to you when i receive them.
  3. #13
    May 2005
    Derbyshire, UK
    Or you could use a http://focus.ti.com/docs/prod/folders/print/pt6653.html to get upto 5a at 5v
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  4. #14
    May 2005
    Reading, Berks, UK
    Carnetix have just released the 1290 it supports 12v and a seperate 5v O/P
    http://www.carnetix.com/CNX_1290.htm
  5. #15
    May 2005
    Derbyshire, UK
    Quote Originally Posted by klokman
    The 1280 has always had a seperate 5v output, and it can also add another one with the new module due for release soon...
    But, spaceman already has a M1-ATX so doesn't need a complete PSU-shutdown controller etc...
    Old setup
    New setup
  6. #16
    May 2005
    Reading, Berks, UK
    You've obviously being doing this for longer than me! I stand corrected, and also have more options for the same problem
  7. #17
    Oct 2004
    i have the same issue with my dvd drive maxing out my opus.
    But im so electonically challenged that i have no idea how or what these regulators are and work.
    If i were to buy a new opus 150 watt psu would this be easy to wire up and would this even be possible?
    sorry for the threa jacking.
  8. #18
    May 2003
    For those who are electronically challenged or just don't want to build their own.
    http://store.cd4power.com/cgi-bin/cd...d/Catalog/1051
  9. #19
    May 2005
    Derbyshire, UK
    Well the TI one I linked to can be ordered as a free sample (multiple times ) and only needs a couple of capacitors adding to it...
    Old setup
    New setup
  10. #20
    Oct 2004
    Glasgow, UK
    Today i received samples of the LM338T regulator.
    The data sheet can be found here http://www.national.com/ds/LM/LM138.pdf
    Im not all that great at elctronics, so i was just wondering if anyone can help to set this up. Ive worked out that i need 2 resistors and maybe a capacitor.
    But i really dont know what value resistors to get and exactly how to set it up. Also, do i need a heatsink?
    Any help would be hugely appreciated
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
    By mattress in forum General Hardware Discussion
    Last Post: 04-05-2005, 07:15 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 02:06 AM
