Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: How to power 5V usb hub from 12v
    Oct 2004
    Glasgow, UK
    I have 2 usb hubs that i need to power from 12v. The hubs need 5v, 2.5A.
    Can anyone tell me what i need so that i can power these from a 12v line from the car, i dont want to power them from my M1-ATX psu as it will probably take me close to maximum power.
    As it will be powerd from the car, would i need a regulator aswell?
    Im not too sure how to go forward from here so any help is appreciated.
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    yup, get a regulator
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Oct 2004
    Glasgow, UK
    So a regulator would regulate the 12v coming form the car, but how do i convert the 12v to 5v?
    Apr 2005
    UK
    you can get regulators that have outputs at different voltages, eg 12 > 14 in, 5 out.
    Type-R Mini
    Oct 2004
    Glasgow, UK
    Thanks, ill look into it
    FLAC evandude's Avatar
    Mar 2005
    Maine
    good luck getting 2.5 amps though... linear regulators are generally only rated for like 1 amp (because of the way a linear regulator works, it dissipates a the voltage difference as a lot of heat)
    if you need 2.5 amps output you'll probably want to go with a switching power supply, which can provide much higher output current without generating nearly as much heat. otherwise, you may have to make some ghetto arrangement of 5v linear regulators in parallel with huge heatsinks.
    check out the max787 or max788 (can't remember which one is for 5v) but those are switching regulators designed for 5A output. you just have to add some external components (inductor, capacitors, etc) but if you can solder and read a schematic you should be able to rig something up.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Newbie Kostas GOLF V's Avatar
    Feb 2005
    I have used 2pcs 7805 regulators with a cooler...
    working just perfect...
    Oct 2004
    Glasgow, UK
    Thanks to everyone who posted their ideas.
    I just used the epia power calculator and im actually using less power than i thought. At idle im using about 3.5A, playing MP3 about 4.5A, and playing dvd at 5A. This leaves me 5A spare.
    For the two hubs i would pull another 5A, which takes me to the limit. But thats assuming that all ports are using 500mA, when some would be less (i think 100 - 125 mA for some devices). Also one hub would have all ports used up, but the other is just to give spare ports if i ever need to plug anything else in.
    Am i right in thinking that the hub would only draw the stated 2.5A with all ports using high power devices?
    With this in mind, do you think i would be ok just to suply the hubs from the psu?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by spaceman
    Sure you can. Or, you can use this regulator.
    Good for 5 amps, and adjustable. Needs I think one or tow external components, a variable resister and a cap, I think.
    Michael
    Oct 2004
    Glasgow, UK
    Im not all that electronically minded, looks a bit confusing with all the different diagrams. Anyway i ordered some samples of it, so ill see how i get on when i receive them.
    Do these maintain a constant output, even with a varied input ( 12-14v)
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
    By mattress in forum General Hardware Discussion
    Last Post: 04-05-2005, 07:15 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 02:06 AM
