Results 1 to 10 of 12
Thread: DennisK system... need some help please?
    Newbie Danrc30's Avatar
    Feb 2005
    I have a few simple questions:
    1) What size is the plus needed to put power into the VGA board? I have a 2.1mm plug for the cable, but 2.1 doesn't fit into the board...
    2) What gauge wire should be used to solder into the board to send power to the touchscreen controller cable?
    3) Which way does the connector go on the touchscreen control board? It's a black connector and it can be plugged in 2 ways. Which way is right? There's an arrow on one side...
    I searched for some answers but I didn't find anything... Can someone help me please??????
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Danrc30
    1) Take the vga board to either Radio shack, or your local electronics supply store, adn test out the plugs they have there. You should be able to find the appropriate one.
    2) No idea what you are talking about.
    3) An arrow on a connector generally means that that pin should be connected to pin #1 on the connector. Look at the connectors for similar arrows, or a red wire, or a wire that is different then the others. If the connector is mounted on a circuit board, look at the board to see if the pins or wires are numbers, or perhaps have an arrow there as well.
    Michael
    Feb 2005
    More info on #2:
    There is a cable that goes from the touchscreen controller board to the back of the carputer for the mouse. It needs 5 volts of power and that can come from the VGA controller board. I tried using 20 gauge wire, but it was too thick. I was wondering if anyone had done this already and what gauge wire they used...
    3) Unfortunately there are no markings on the board that tell me which way the plug connects. On the board, the pins stick up and then they all bend 90 degrees. The arrow can either face up, or down towards the board depending on which way you decide to plug it in. Can someone tell me for sure which way it goes?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    More info on #2:
    Well, the cable that goes to the back of the carputer/ps2 port and the VGA board should have 5 volts on it already. Is there a particular reason that you want to take the 5 volts from the VGA board? I am not familiar with this unit though.
    As for 3, wish I had more advice for you.
    Michael
    Feb 2005
    The directions show a 5.0 x 2.1 plug with 5 volts of power to connect into the touchscreen controller cable. I spoke with the creator of this system and he said it's required, and the 5 volts can be drawn from the VGA controller board. The holes are tiny in the board for the 5 volts so I was wondering what gauge wire people used.
    I did ask him about the black plug, but unfortunately he didn't have an answer for me.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    It most likely isn't drawing much current through that wire. Something that fits the hole should work fine. Just keep the lenth as short as possible. Something like a 24gauge wire should work fine.
    Michael
    Feb 2005
    Ok, almost everything is done. The soldering on the VGA board was really rough, but I got it. Got the right connector from the Shack.
    All I need is for someone with this system to tell me how to plug that touchscreen into the touchscreen controller board. It's a black plug that goes into pins that stick out of the board. But which way does it go??? It fits on both ways! Please, can someone help me???
    ddn
    ddn is offline
    Dec 2004
    I'll have to look on mine later. The black connector has a very small arrow on it, but I can't remember which side it goes to.
    Feb 2005
    Yes, all I need to know is where the arrow is supposed to be located... Then I'm all done....
    Feb 2005
    Quote Originally Posted by ddn
    Did you get a chance to look yet?
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 02:39 PM
  2. quick system disconnect idea
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-14-2005, 11:35 AM
  3. FS: Carputer system w/o monitor
    By Toups in forum Classified Archive
    Last Post: 04-21-2004, 01:43 PM
  4. linux system owners with web site please post
    By Jake in forum General MP3Car Discussion
    Last Post: 10-23-2002, 09:39 AM
  5. WTB: Complete Dennisk 8.4" setup
    By tf82 in forum Classified Archive
    Last Post: 10-13-2002, 07:54 PM
