Results 1 to 5 of 5
Thread: QUestion! HP e-pc modifications....
    Jun 2005
    Hi all!
    I'm new here, but I build computers for a living and in the meantime I restore classic cars. I'm trying to get my hands on a carputer for my Early Bronco, or maybe for my daily driver....but either way, I have a few quick questions:
    1. What does the majority recommend....a buildup using a mini-itx case and aquiring all the parts I want, or purchasing a HP e-pc (alot cheaper) and adding a few things to it?
    2. (the main question) Has anyone ever taken a HP e-pc and gutted it to upgrade it with a mini-itx board? In other words...the HP e-pcs only come to a max of (I think) 1.7 ghz, and I want the ability to have future upgradeability, but will a mini-itx form factor board fit in a hp case?
    Will the PS work with the new board?
    need to be modified?
    My goal is to get at least 2.5 ghz on the board, a dvd drive, a regular size HDD (at least 150 gig), without making something that may overheat.
    I think the HP setup is great, and it uses a regular HDD, but takes a slim media drive (I'm trying to get everything regular size...parts are ALOT cheaper that way)
    Any suggestions?
    Thanks!
    May 2005
    Hdd
    The only fault i see is with the HDD. Make sure to mount it vertically. I am going to be using an E-Vectra in my install and my primary concern is the HDD. 3.5 inch drives are not to good at handling road vibration.
    Jun 2005
    Vertically?
    I've seen many HDDs take abuse quite well, and I'm not trying to be rude...but has anyone else had a problem with this?
    Thanks for all responses!
    Elsewhere
    Gentlemen.....
    There is lots of threads about this. There is no definitive answer to the vertical vs. parallel debate.
    Searching on hard drive mounting yields them...
    How about the Wiki?
    Jul 2005
    Calgary
    no internal power supply on e-pc
    I don't think the e-PC has an internal power supply. talked to a dealer that blows out mass corporate lease-returns for a couple hundred bucks and he said they use an external ac adapter like a laptop. I'm assuming its a brick. I was hoping I could just swap out the psu for an opus and get an instant SFF car pc. if you have new or diff info pls let me know....
    99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
    97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
    currently: installing (finally!)
  1. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 01:49 AM
  2. Regular PC Question
    By Nav_Attack in forum General MP3Car Discussion
    Last Post: 10-19-2004, 09:03 PM
  3. car pc, speakers question
    By icet in forum General Hardware Discussion
    Last Post: 02-27-2004, 02:42 PM
  4. For Sale HP Ipaq H2215 Pocket PC
    By Santa Cruz in forum Classified Archive
    Last Post: 01-28-2004, 01:33 AM
  5. dumb question. how do you turn on the pc?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 04-03-2001, 01:49 AM
