Results 1 to 3 of 3
Thread: Computer powers up but no VGa signal
    Constant Bitrate dexy's Avatar
    Jul 2004
    I just bought the VIA EPIA PD10000 Mini-ITX motherboard. We fired up the motherboard and the BIOS came up fine. We restarted it a few times to test the ACC switch. We had the IDEs hooked up to IDE2 and desided to switch them to IDE1. After we changed the IDE source the VGA output stopped. We hav't been able to get a VGA signal on any Monitor. Master's and Slaves are set properly and all the wires have been tested for output. We can't find any information on how to set the motherboard's BIOS. If anyone has had a similar problem please share your solution.
    Raw Wave
    Jun 2004
    On the beach
    If you remove the drives completely what happens?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    1.Remove usb devices,cards (if you have any ) no familiar if the PD has an expansion slot or not
    2.reset the system configuration data...... short pin 1-2 (default 2-3) with the power off and then return to the default position.
    3.Try another PSU
    try all this points one by one (if #1 doesn't do it go to #2 and then #3) and see what is the resoult.
    Good luck
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. Cleaning VGA video signal
    By Destin in forum General Hardware Discussion
    Last Post: 12-28-2006, 11:17 PM
  3. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  4. LCD signal differences - composite vs. VGA
    By laxrox in forum LCD/Display
    Last Post: 11-12-2001, 03:15 PM
  5. How to wire up a tft screen to analogue vga card
    By darkwingduck in forum General Hardware Discussion
    Last Post: 01-12-2000, 10:01 AM
