Results 1 to 10 of 10
Thread: DISTRIBUTION BLOCK cant find the right one
    Jun 2005
    Bellevue
    cant find a DISTRIBUTION BLOCK with a 2 gauge input and a 4 gauge out put??? were can i get one????
    Jun 2005
    Bellevue
    o ya and it has to use AGU GOLD FUSES and have 4 outputts
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    You're looking for a single input and a single output? Remember that AGU fuses only go up to 60 amps...
    EDIT: I saw you need 4 outputs. Best Bet would to get a 0 guage input and 4 guage outputs. I'll get a link for you.
    Dec 2003
    Edmond, Oklahoma
    I'm bought this one: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5783140359 It uses ANL fuses though.
    Any reason why you have to use a AGU fuse?
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    There are couple here that are close to what you are looking for.
    http://www.stingerelectronics.com/we...stribution.asp
    Newbie ScubaX's Avatar
    May 2005
    Monterey, CA
    Here is one that has 2x 2/4 input and 1 x 4/8 out and 3 x 8 out with AGU fueses. If you need all 4 out to be 4guage then you might look around that web site for others they sell.
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    I've got the one posted above by ScubaX. It's better than the Rockford distro block that I had before this one (4-ga in with 2 8-ga out).
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Jun 2005
    Bellevue
    i was thinking of using AGU beacause my speackers amp is only 300Watts and i need a 30 amp fule so ya..... is it better useing something else....
    Jun 2005
    Bellevue
    and im also running a 500/1 jl audio amp on that also...and a computer so idk if it is all going to work out
    Mar 2002
    Austin, Texas
    Just remember, if you go with the distro block like I've got (the one pictured above), you need a fuse in each slot even if there is no connection in use or the alarm will go off constantly because it thinks you have a blown fuse.
    Derek
  1. where can I find low profile sound card?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-04-2006, 02:05 PM
  2. Where to find WindowSearchString?
    By Learic in forum MediaCar
    Last Post: 06-13-2004, 11:37 PM
  3. Where to find "classic" styled buttons?
    By rhurley in forum General Hardware Discussion
    Last Post: 05-24-2004, 12:15 AM
  4. need to find an adaptor for the 12vDC on the back of the lilliput screen
    By DSM97RS in forum General Hardware Discussion
    Last Post: 04-17-2004, 06:21 PM
  5. Replies: 5
    Last Post: 07-12-2003, 02:43 AM
