Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Amplifier Control - Avoiding "Thump"
  1. #11
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    Well, you should check, it could be that your GPS and/or phone communication software already lowers DTR when going into hibernation. Then you're all set, just tap into the DTR line in the connector somehow.
    Custom Linux system on an '89 VW GTI 16V Edition One
    Jogdial volume control, Sony joystick, IR remote...
    Used to be the fastest Linux on the road, until all these NOS types came along...
  2. #12
    Nov 2001
    Scotland, U.K.
    Post
    I'll take a look at it tonight!
  3. #13
    May 2001
    Dunstable, England
    Post
    The remote switching wire for my amps is 12v - is the DTR on a serial port 12v?
    Best regards,
    Darren Thrower
    http://www.percyt.com/mp3player.htm
  4. #14
    Nov 2001
    Scotland, U.K.
    Post
    I think RS-232 is +?v-12v for high and -?v-12v for low. I would not like to connect the output directly to an amp, use an optocoupler or small relay buffered with a transistor. I like plenty of isolation in these situations. Gives you flexibility too.
  5. #15
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    The RS-232 spec is +3V to +12V for high. Most motherboards produce 9-10V or so, which is high enough to activate the amp's remote turn-on.
    You can use a relay if it will make you feel better. I just put in a small fuse -- I feel there's not much that can go wrong with a serial line driver, apart from overloading it, which the fuse ought to protect from. The current draw of the amp's turn-on line ought to be very small, but check your specs.
  1. Voice control for Winamp
    By VoodooVoice in forum Software & Software Development
    Last Post: 08-01-2006, 05:19 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  3. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
