Results 1 to 8 of 8
Thread: Slim Line CD Rom
    Oct 2004
    Slim Line CD Rom
    Hey guys question, I just got a TEAC slim line cd rom (cd-224e) I got the IDE to Slime line adapter. I plugged into the second IDE channel on my M10000, I turn it on and the light on the cd-rom stays solid, I cant open it and the mo-bo cant see it.
    ANy ideas?
    Low Bitrate homchz's Avatar
    Jun 2005
    Lee, NH
    Secondary port or secondary ribbon port?
    Are the slave/master jumpers correct?
    Joshua Jones - New Folk Singer Songwriter & Web Site Design (Yep, that's what it says)
    Plans:
    Micro ATX MB, 1.6 Ghz AMD AthlonXP-M, 512MB RAM, 20G 2.5" HD, Thinline DVD, 10" Touchscreen Display (Front)
    Web Log
    FLAC evandude's Avatar
    Mar 2005
    Maine
    and did you remember to power it?
    from what i've heard, when you plug in the IDE cable but forget power, the drive tends to light up but not work. also, CDROMs usually allow you to open them even if they have power but no IDE cable... so if you have power you should at least be able to open it.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Oct 2004
    The Secondary IDE port on the mobo, There are no jumpers for this drive its cable select and yes its powered.
    DST
    DST is offline
    Jun 2005
    does the IDE cable have the notch in it to ensure it goes in correctly? I know with floppy drives if you put the cable on the wrong way the light comes on solid.
    What about flipping the cable? Or a whole different cable?
    Just a couple ideas. Ive seen some wierd cable configurations before, usually only for floppy drives though.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    If it's Cable Select, then you need a special cable, don't you? (SWAG) And I think you'd have to set the primary drive to Cable Select as well...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    DST
    DST is offline
    Jun 2005
    Going off Hard Drives, cable select is pretty common, I think its' the default shipping configuration...at least for places like Seagate, and the cable the drives come with have always worked for me. No idea what would be different for a CD drive though.
    Oct 2004
    Hmm Different cable for cable select huh?
    Ya the IDE cable only fits one way.
  1. Slim Slot Load DVD Rom - Do They Exist?
    By J-Fame in forum General Hardware Discussion
    Last Post: 03-12-2005, 01:40 PM
  2. FS: External Slim Line DVD burner for sale!
    By EsKALad in forum Classified Archive
    Last Post: 02-06-2005, 07:48 PM
  3. slim slot dvd rom with wrong adapter, questions
    By mattress in forum General Hardware Discussion
    Last Post: 10-24-2004, 08:51 PM
  4. Using CD Changer Line In with MP3BOX
    By Addie in forum General Hardware Discussion
    Last Post: 04-14-2002, 12:14 PM
  5. Kenwood KDC-7007 w/MP3 thru the CD Changer control line?
    By Smeghead in forum General Hardware Discussion
    Last Post: 11-04-1999, 01:02 PM
