Results 1 to 6 of 6
Thread: Problems with XM Direct Cable
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    Exclamation Problems with XM Direct Cable
    I have been using the same XM direct cable for months. Recently I changed motherboards from the epia m1000 to the epia mII 1200.
    The problem I am having is it is not indicating a signal from my XM reciever in any software. It is all connected correctly just no data. Is there something more I need to do to enable the com port.
    Windows shows comport 1 and 2 as working properly under device manager.
    [EDITED]
    Problem resolved bad cable.
    Anyway, since then (with new cable) my computer does not allways boot up correctly from hibernation. Wont boot at all mater of fact. When shutdown completely it works fine. Is this a known issue?
    You can still have something if you have nothing
    Aug 2004
    Milwaukee, WI
    Anyone have any ideas for me?
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Do you have the pinouts for both motherboards? It may be different on the MII.
    Are you using the serial riser cable?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Oct 2003
    Poland, OH
    Well I just looked at the MII and it has the same pinout as the onboard M10000. Are you sure you plugged it in the correct direction? The red line goes towards pin1.
    Aug 2004
    Milwaukee, WI
    just using the normal serial port
    Aug 2004
    Milwaukee, WI
    Problem solved, cable was toast. Removed the outer insulation to find the wiring melted together and brittle. Dont know why it happened, but it did.
    Oh well, made another works fine now.
  1. XM Direct and Antenna Placement
    By vexter0944 in forum General Hardware Discussion
    Last Post: 04-13-2008, 10:47 AM
  2. Got My XM, But Whats with my Cable?
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 01-08-2008, 06:55 PM
  3. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 03:07 PM
  4. How do I get the XM direct unit to work?
    By minghi in forum Off Topic
    Last Post: 04-22-2005, 06:52 PM
