Results 1 to 5 of 5
Thread: Laptop drives vs desktop drives as far as power draw
    Dec 2004
    Where its windy
    I'm trying to decide if I want to switch from a laptop hard drive to a desktop drive to gain capacity. Whats is the difference as far as power consumption goes? How about as far as optical drives go?
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    as far as I know desktop drives utilize the 12 volt line for all the mechanics and 5 volt for all logic and such. Laptop drives just use the 5 volt line.
    Computer:
    COMPLETE SYSTEM OVERHAUL!!!!!!
    STAY TUNED IN THE UPCOMING WEEKS!
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    K, think of it this way.
    Wattage=Volts*Amps
    So, assuming that most HD and Optical drives utilize about 1 amp (If you check, you will see that to be the case, generally) that means a 2.5 drive using 5 volts and 1 amp is using 5 watts, but a 3.5 drive using 1 amp and 12 volts is 12 watts, or more then double the wattage. Multiply that by several drives in a system, Say a 3.5 HD and a 3.5 Optical drive, and you have 24 watts versus 10 watts for 2 2.5 drives.
    Michael
    Nov 2004
    Cali
    You can always check the specs you know. Doing that will show you that with newer stuff, Wiredwrx is about right, the number are even smaller now with most of hardware.
    I have found you an argument; I am not obliged to find you an understanding.
    Dec 2004
    Where its windy
    I ran into a odd problem today. Yesterday I had my system installed and running using a laptop HDD and optical drive. Today I transplanted everything into a new larger case with desktop HDD and optical drive and the inverter was being overdrawn and wouldnt come on. So I disconnect both the drives with the same result. I'm running a 750W inverter and a Antec 330W ATX PSU. The PSU draws a max of 8A at 115V. In the past this PSU ran fine without any issues. I pulled out the 330W supply and put in a 120W generic supply and everything fired up fine. That is until I tried watching TV while installing software and using the GPS. Thats when the system shutdown. I unplugged the PC for a few seconds and plugged it back in and once again I was in business. I havent tried loading it up again but its working fine now. I just purchased a 150W supply tonight so that should give me the little bit of juice I need.
  1. Laptop Power On I've Searched Help Please
    By TimStark in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-28-2007, 07:59 PM
  2. Power laptop from headunit?
    By LordSnow in forum Newbie
    Last Post: 04-07-2005, 10:25 PM
  3. Options to power 15" desktop LCD from 12vdc
    By MVShibui in forum Power Supplies
    Last Post: 04-01-2005, 08:31 PM
  4. power draw from laptop
    By jstrain in forum General Hardware Discussion
    Last Post: 11-23-2004, 04:35 PM
  5. lilliput / laptop current draw
    By smonice in forum Power Supplies
    Last Post: 08-26-2004, 11:18 AM
