Results 1 to 4 of 4
Thread: How can I access extra USB ports on EPIA MII-12000
    Newbie umarth's Avatar
    Oct 2004
    I've got me self a VIA EPIA MII-12000 mobo and installed WinXP.
    When I go to the device manager it says that I have 3, yes 3, USB Root Hubs.
    Now I'm assuming 1 hub is servicing the 2 USB ports on the back panel.
    So what are the two others? More importantly, can I use them? Cause what I whant to do requires from 5 to 6 USB ports and, if at all possible, I dont whant to use an external USB Hub (from what I read, they dont seem to work so great).
    Any hints???
    [■■■■■■■■■■■■■■■■■■■■] 50%
    PC installed
    EPIA MII-12000, 256DDR, Opus 150, Xenarc, 30Gb/7200 HD, USB Wifi.
    Waiting for: GPS & Soft, eternal Sound Card + Amps.
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    check the manual, there is a connector on the motherboard (near the FDD connector) that is your other usb connector (it is not a normal usb connector, but a row of 5 pins next to a row of 4 pins). you want to connect something likethis to that plug.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Sure you can use them (for a total iof 4)
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Oct 2004
    Doh! It never occured to me that there where extra connectors directly on the mother board! I just looked them over and this mobo is packing (at least for my needs)!
    Even better now that I have found a CF GPS receaver. Now I only need 4 USB ports. so no more need a USB hub!
    Excellent, truly thanks!
    PC installed
  1. Need three serial ports on VIA Epia - OK?
    By nxt125 in forum General Hardware Discussion
    Last Post: 01-27-2006, 03:24 PM
  2. Replies: 0
    Last Post: 04-25-2005, 03:09 PM
  3. extra usb external drive-how to add to directory?
    By glennwoudenberg in forum MediaCar
    Last Post: 12-26-2004, 04:51 AM
  4. cheapest price via epia mii 12000?
    By jdub421 in forum General Hardware Discussion
    Last Post: 10-22-2004, 10:45 PM
  5. Via Epia Questions - need multiple serials, ps/2 ports, USB
    Last Post: 08-07-2002, 08:08 PM
