Results 1 to 10 of 11
Thread: Case Questions - Epia / Opus 90W
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Looking to make a case to hold an Epia M10000, Opus 90W and a hard drive, today I found the attached cash box that looks like it might be ideal, however I have a few questions. The case, if you're interested, is a $12 cash tin from Walmart.
    As you can see the Epia an the Opus fit quite neatly although it isn't on standoffs yet and height may become an issue. If you look at the side view you can see the sound block pokes up too high although the cover still closes and locks without having to be pressed.
    My hope is that I can mount the HD on the inside of the lid where clearance permits.
    So, to the questions:
    1. Should I add any vents? If so should they be above the fan?
    2. Should I add another fan?
    3. Ports - should I jst cut the end out or can I get a template to fit the Epia and mount that in the end to keep things neat?
    4. Should I be concerned about the sound block touching the lid? I assume it will not cause a short, but I could also cut a hole around it but it will then look messy.
    Comment/suggestions most welcome.
    Chris.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    1.yes you can make vents on the top and on the sides
    2.If you can ..... I got 2 40mm (people say that they are noisy but is no true) this is a car pc!!
    3.make a hole of the size of the backplate (it looks beeter that just a hole)
    4.cut the standoff to make the MOBO go low.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Nov 2003
    Massachusetts
    Thanks, where do I get a backplate?
    Nov 2004
    It didn't came with the board??.....
    Nissan Aux-in MOD
    Nov 2003
    Massachusetts
    Nope, unless I missed it. I bought it used, will check with the seller.
    Nov 2004
    If not ..... to tell you the true I saw another guy looking for the same item a couple months ago and we didn't find any place with the right one.
    Maybe wwdigital
    Edit:
    You see... this is what I'm talking about
    WTB: Via Epia M10000 I/O Shield (Backplate)
    Nissan Aux-in MOD
    Nov 2003
    Massachusetts
    Damn... if I hack up and old P1 PC should the backplate fit?
    Elsewhere
    Quote Originally Posted by ukchris
    Doubtful.
    Backplates are typically cut to match the motherboard.
    How about the Wiki?
    Nov 2004
    What you can do in this case is ask one of the guys that you got the MOBO to take a pic of the backplate and then you make a template and make yourself one in plexy.
    Nissan Aux-in MOD
    Nov 2003
    Massachusetts
    I have made a scale template from the diagram in the doumentation on the Opus web site. I think I'll start with a paper cutout and if that looks good either make one out of a think sheet of steel, or plexi or cut the holes straight into my case.
  1. I fit an opus 90w in Morex case, Pix and a few tech Q's for safety
    By Tim97rs in forum General Hardware Discussion
    Last Post: 05-10-2005, 01:36 AM
  2. opus 90W questions
    By okeydokey in forum Newbie
    Last Post: 04-03-2005, 04:23 AM
  3. FS: Opus 150W, 60GB HD, Sereniti case
    By aoLhaTer in forum Classified Archive
    Last Post: 01-30-2005, 04:38 AM
  4. BEWARE: Epia V8000 & Opus 90W combination
    By Jailer in forum General Hardware Discussion
    Last Post: 12-28-2004, 08:57 AM
  5. Opus + Epia.. How to get it in the case?
    By ShinkunoNamida in forum Off Topic
    Last Post: 12-28-2002, 11:47 PM
