Results 1 to 4 of 4
Thread: EPIA-800 x1G of RAM won't play DVD's - HELP
    Newbie Keebortz's Avatar
    Jun 2005
    Unhappy EPIA-800 x1G of RAM won't play DVD's - HELP
    I've recently helped a friend of mine install a EPIA-800 with 1G of Kingston/133 and it will not play dvd's without clipping.
    DVD player is a Panasonic CW-8124-B with the IDE adapter.
    Hard drive is a Maxtor 40G / 7200 RPM
    Power supply is a Mini-Box M1-ATX (Same issue with a 300w ATX Power supply)
    Front end is Frodoplayer
    Windows media player is v10
    O.S. Windows XP SP2
    Any more information needed please let me know, any and all information will help.
    I do have a second issue if someone wants to give me a tip, the mouse will jump around the screen clicking all over the place at random. A reboot fixes this, but if someone has a tip I'd appreciate that too.
    Thanks in advance,
    Tim
    Oct 2004
    Make sure that the IDE controller used (primary or secondary) is set to use DMA and to PIO transfer mode in the device manager:
    Open Device Manager, browse to IDE controllers -> Primary/Secondary IDE channel, rightclick and choose props. Then choose the 'Adv. settings' tab and make sure it says 'DMA if available' as transfer mode.
    Also, You might wanna check if it clips in all players - if it works in for example WinDVD/PowerDVD but not in MP10 then it's most likely a codec issue. Make sure You only have one audio codec and one video codec installed in order to minimize hazzle.
    ich bin anders...
    Jun 2005
    Quote Originally Posted by ambush
    Do you have any suggestions of Codecs to use?
    When it comes to doing them seperate... thats new to be. I'm assuming an AC3 codec for the audio right?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i'm curious to see if anyone else has this issue with the EPIA 800... i was just about to drop $$ on a slot load.
  1. FS: EPIA 800 ITX Motherboard
    By dr1ft in forum Classified Archive
    Last Post: 08-05-2003, 09:57 AM
  2. Replies: 3
    Last Post: 05-19-2003, 02:59 PM
  3. epia 800 video ram
    By kane2g in forum General Hardware Discussion
    Last Post: 04-27-2003, 08:29 PM
  4. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
  5. FS: Shuttle FV24 with Celeron 800 and 128mb ram
    By Mikesz in forum Classified Archive
    Last Post: 02-18-2002, 02:56 PM
