Results 1 to 7 of 7
Thread: Power Switch
    Apr 2005
    Queens, New York
    Power Switch
    Hey I was just wondering it is possible to put a switch on the power cable going to the opus? The power as in the direct power cable from battery. IF not where can i put a switch besides on the remote like cuz i already go one there. IF the car PC ever "FREEZES" and stops respondingm if i flip that switch on the remote line wiht the pc eventually turn off? I have a 10second turn off delay....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Maximum Bitrate kirbycope's Avatar
    Apr 2005
    Metro Denver
    I dont see why not
    Post Whore's tip:
    User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
    http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I would recommend the use of a relay, you don't want to be switching that high current wire directly from your dash.
    Apr 2005
    Queens, New York
    Well i would wanna be able to cut the power to the pc and then flip it back on....basically to turn off/turn back on
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Elsewhere
    Quote Originally Posted by Cheekz185
    Searcht he forums. I know this has been addressed. If I remember correctly, there's even wiring diagrams to do exactly what you want.
    How about the Wiki?
    Jun 2003
    Fairfax, VA
    A relay allows you to use a low current (safer to run to dash) to switch a higher current (not so good to run through dash)
    http://www.the12volt.com
    lots of schematics there
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Why don't you install a regular power switch from the mb (like the case has) and just hold it down for six seconds. It should shut the power supply off and then you could turn it back on immediately.
    - Jeff
    edit: I just saw that you have an ITX setup - I don't know if they work like an ATX power supply...
    95 Mustang GT Convertible
    87 Mustang GT Convertible
    My Project | Let's Go Mets! | SCT Tuners
    Project Status [===#===] [Bezel and dash creation]
  1. Need help with X31 port replicator power switch
    By viguera in forum General Hardware Discussion
    Last Post: 06-22-2005, 12:12 PM
  2. Bridge batt power for relay switch?
    By Ascension in forum Power Supplies
    Last Post: 06-20-2005, 05:38 PM
  3. power switch for mii12000
    By kilomo in forum General Hardware Discussion
    Last Post: 03-16-2005, 12:11 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. extending a ribon power switch...or where to get a new one
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-15-2001, 05:51 PM
