I have to be within about 20ft to open my door and the GPS is accurate to something like 50ft depending on lots things, or what is it? Anyway, I think a button is easier.
A way to use the GPS to automatically trigger your garage door to open when you return home. I've got to have that!
Well, ok, not quite yet. I need to get my house extension done so that I actually have garage doors...
Ha! That would be tight. I want one too.Originally Posted by Arathranar
my wish list:
http://i4.photobucket.com/albums/y13...tSignature.jpg
When mine has a lock (takes a while), it's accurate down to about 1ft. Certainly good enough to open the garage door in time.Originally Posted by Curiosity
What if it gets a lock right as you're pulling out of the garage and doesn't know the door is already up? There are just too many things that could go wrong. It has to know that you are coming home, within range, etc.
What if human beings had never learnt to use tools because they might hit their thumb with the rock? Luckily we're not all as negative.
Sure, there will be difficulties. But nothing that seems unsurmountable to me.
If my car PC was turned on and the the last GPS lock when it was turned off was near home, then it will do nothing (my GPS takes too long to lock to be usable to close the garage door unfortunately - which probably makes this a moot point for me but still worth coding for).
As for the rest of it, the point of a GPS is that it knows where you are (fairly accurately these days unless you have a crap receiver). So knowing when you are in range is the trivial part.
As for whether you are coming home. I guess you could have a house that you could drive within range of but not actually be returning to and just driving past. You could fix that in two ways - either don't have such a house (like me) or shorten the distance needed to fire the garage door opener so you actually have to be pulling up to the garage for it to go off.
And it's trivial enough to determine the direction the car is travelling. So you could restrict it to only fire when heading towards the garage. Then an instantaneous gps lock when leaving the house (oh I wish I could get that) would be ignored since it would note you were driving away.
try to use something more localized
not GPS
but maybe the garage has a built-in unit that detects something in the car and will open the door when you get close
[||||||||||||||||||||] - final touches
SUPER 7" VGA w/ TS
Toshiba Satellite 3000
P3 850
256MB
30GB
Geforce2 Go
DVD
Orinoco 802.11b PCMCIA
nlite WinXP 350MB installed
RoadRunner
iGuidance 2.1
Holux GM210 GPS
Xantrex Xpower 300
or when your WiFi AP is detected
AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
Zenarc 700TSV Netgear USB WiFi GPS Opus 150
Running Win XP, FP, MM
you could always also just wire up some sensors so your carpc will know when the garage is up and when its down...
if you get within range and it senses its down.. then it has to open it
the problem is when you want to close it
