Use Motherboard Monitor 5. Freeware, and best thing out there!
also known as mbm5 google it!
EDIT: It will monitor everything related to your CASE. Sorry, know nothing about outside temperature monitoring...
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Already using mBM5 but it sucks. It doesnt give me accurate temps....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Sorry to hear that. Works very well for me, and is insanely configurable. Its what most folks use in this forum.
2002 Honda CR-V
IM thinking about doing a Phidget setup. With an 8/8/8 controller fo $100 And Get 4 analog temp sensors to connect to it.....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
How hard is it to work with Phidgets? Installing them and programming them?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
If it does no give you accurate temps ypu can change the sensor type in the program and see if it gives you better results
Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
Download the German Voicepack 1.0 for FreeDrive now!
I agree, MBM5 does suck the proverbial, but it is freeware and well you can't be free.Originally Posted by Cheekz185
If you were going for a custom solution, I would look at the Dallas Temperature Sensor series. I've built some embedded temperture monitoring solutions for people using these things and they are AWESOME.
Very easy to string a few (or many) together for an insanely verbose temperature monitoring system
Caputer Mk. II
'02 VX Holden Commodore Series II Executive
MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
Morex 60W DC-DC, Custom S/SDC
OS/Software: Developing...
Hey thanks for the info, I tried Googling Dallas..... but couldnt find there main site. Can you send me a link of there products and where i can purchase them.Originally Posted by OdysseyPC
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
I found something at QKits.com But i dont believe this unit comes with any software. How would i get it to tell me the temperatures?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
