Results 1 to 10 of 14
Thread: Power your car amp, in your house, with a computer power supply
    Newbie syfenx's Avatar
    Jan 2005
    a place in TX
    i read, read, and then read some more.. found most of the same info on how to do it, but i didnt find anything visual.. i decided to do it.. so here it is..
    (i used the same amp as in the picture by the way..) if it helps it helps, if not then, contact me via my site, i can help you out.. either way.. just trying to help out, ive wanted to do this forever, so i hope it clears some things up for alot of people.. it did for me..
    EDIT:!! connected = on, pin 14 and 15 have to be connected for the power supply to be active, or turned on!!
    www.sys9.net = my site
    syfenx@gmail.com = my email
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    thx. i need to take one of these days and test my amp. still have no clue where the damn remote turn on lead is.
    Your everyday carpc geek and tech guru at your service. *bow*
    Jan 2005
    a place in TX
    what do you mean.. "damn remote turn on lead" .. the center rem terminal?
    if so.. just attach the 12v yellow wire to it, as in the picture..
    Jan 2005
    I'm guessing that the pin 14 & 15 have to be connected so you can recieve power, And on pin 11 it can be either orange or brown? EDIT: I guess he got my note on how it was might be confusing.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Brown is a mistake
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Zac
    Zac is offline
    Feb 2004
    VA
    lol - just don't use a power hungry amp or your ps is toasted...
    I played around with this for awhile using those emergency rechargable jumpstart battery packs...worked fairly well....
    Jan 2005
    Warren, Ohio, USA
    Quote Originally Posted by syfenx
    no. its that the amp i have which is OEM doesnt indicate any kind of turn on lead in the wiring diagram. im assuming it senses current on the input lines and turns on when it receives a signal, but im not 100% sure. its all a wait and see. plus i still need to get the proper wiring harness which will set me back another $25-30 (which is pricey for my current budget. a broke-*** college student with no job. )
    Dec 2003
    Germany
    Another thing to consider is that the PSU won't put out enough power on the 12V line to fully power the amp at 100% voilume so you have to be careful not to fry it.
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    May 2007
    Power supply shuts down when I connect amp
    Hey there
    My dell power supply shuts off as soon as I connect the amp, anyone know why this could be happening?
    Carmen
    Low Bitrate Cruelkix's Avatar
    May 2006
    Denver, CO
    Quote Originally Posted by cbranje View Post
    Hey there
    Carmen
    I would guess you either have a short somewhere or the amp is drawing to much power and the dell ps has a built in auto shut off to protect it from overload.
    I would double check your connections and also ... turn the gains down maybe??
    Audio - Performance Teknique 5.1 Digital Amp, Kappa Perfect 12" VQ
  1. Replies: 9
    Last Post: 01-18-2005, 09:00 PM
  2. Switching from Car to House power?
    By Deadnick in forum General Hardware Discussion
    Last Post: 01-11-2005, 09:09 PM
  3. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 10:25 PM
  4. car amp power supply
    By fuctup in forum Power Supplies
    Last Post: 11-03-2004, 02:52 PM
  5. Replies: 0
    Last Post: 06-14-2004, 11:36 PM
