Results 1 to 10 of 14
Thread: Selectable Power
    Mar 2001
    Regina, SK. Canada
    Lightbulb Selectable Power
    Hey guys. Here's something I'm working on for my project. Since I may want to show off the system while sitting in the driveway or something like that, instead of having the car sit there and run why not hook the computer up to a extension cord and plug it into the house? So I went and got a SPDT switch from Radio Shack. I'm going to cut the positive outputs from the inverter and the extension cord and hook them up to the switch and then have the switch output go to the power supply.
    Now comes the questions. The switch is rated at 6A at 125V AC, will this be able to handle the computer supply? Since there's only 3 single connectors on the switch, where do the negative and ground cables get routed? Can I just connect them straight up to each other? Also, the connectors on the switch are pretty small. How do I connect the fairly large power cables up to it? Are there little spade connector things I can get that clip on?
    Thanks for all the info!
    P.S. Make sure you read my post about LCD controllers. I'm still trying to work out a good way to hook up my LCD.
    AMD Duron 750, 128m RAM, 10gig WD, 12.1" TFT screen, SB Live! 5.1, custom plexiglass case
    TalonTemple.com
    TalonTemple.com
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Smile
    Why not just connect the computer straight to +12V with just a switch??
    A SPDT switch will not work. You need a DPDT switch.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Mar 2001
    Regina, SK. Canada
    Post
    What do mean, "connect it to 12 volts"? The only part of the computer that would see +12V would be one of the wires running from the power supply to the motherboard? How do I connect the two input wires to the power supply is what I'm asking.
    TalonTemple.com
    TalonTemple.com
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    If it was my set up, here is what I would do -
    use a DPDT switch
    To PSU 12 V -| |- To Psu
    To Inverter -| |- To Inverter in
    To Car Bat -| |- To Car Bat
    Use a 10 Amp switch.... or whatever switch you want hooked to a dpdt relay, with the relay wired as shown above.
    Hope this diagram formats right
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Jul 2000
    Orlando, FL
    Post
    How about unplugging the power cord from the inverter, and plugging it into the extension cord?
    Mar 2001
    Regina, SK. Canada
    Post
    Not gonna happen. Power supply and inverter are going to be buried deep into the dash. The only part of this computer project that anyone will see is the screen, which will be folded up all stealth-like most of the time.
    TalonTemple.com
    TalonTemple.com
    Jun 2000
    Salt Lake City, UT, USA
    Talking
    You could always make a spot under the hood where you can switch it from the externtion cord to the inverter. Then it would be out of sight and still accessible.
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
    Jan 2000
    Wink
    <font face="Verdana, Arial" size="2">Originally posted by dan0myte:
    </font>
    Sorry. Even I don't remember what I was trying to say...
    Aaron Cake
    Mar 2001
    Regina, SK. Canada
    Post
    Haha, nice one Falcon but I lack the energy to get out of the car, pop the hood and yank out plugs every time I wanna run the computer at home. I just want to lazily hit a switch and that's it.
    TalonTemple.com
    TalonTemple.com
    Jul 1999
    Greensboro NC
    Post
    Hey dan0myte check your mail I sent you a schematic of a little relay circuit that should do the job for you.
    Catlas
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  3. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:14 PM
  4. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
