Page 5 of 21 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 201
Thread: Sirius Usb Interface
  1. #41
    MySQL Error
    Oct 2004
    frodobaggins,
    what do you need...
    I'm not at all familar with your software
    I have c# code and .dll available
    the .dll is a .net class with all you need to talk to the radio
    and delagates events back the caller
    mitch
  2. #42
    MySQL Error
    Oct 2004
    I have 5 of the SCfm1 design(shown in pics above) pcboard coming, thursday.
    I will assemblem them, and sell them for a developer price of $35 each.
    (i got a few hundred dollars out there. so ill sell these for my parts cost and no labor fees, just to get the coding going...)
    this board can be used on ANY Sirius Connect, does not 100% need the SCFM1, but the FM1 has the holes in the correct place for my board. if you use a cheaper say ALP1, the cover will not go back on... or u will have to make your own holes... Id say for developing this is fine(without cover)... ALSO this directly has no connection for autos, ie wires, it uses a 1.3mm DC power jack for power... i supply the WALL Adapator (12v 300ma), in a CARPUTER u need to get own connector (or chop the supplied one) and make the connection, could use the 12v from the carputers power supply... this version does have a turn on, but its not directly exposed, its on a jumper, you could just supply 12V as accessory... there is no harm removing 12v from this unit when its off. as soon as the boards hit, ill do some final current draw tests.
    again this was designed for HOME use, where a wall apdaptor is fine, and always powered is fine...
    I have the New ALP1 design ready to go, that has a exposed 12V turn on.
    I have to do some final checks on the board, then out to manufacturing
    the pboard is costing me the most, in low quantities, and i dont know how many I will sell.. so i will prob not run more then 50
    which ofcourse keeps the $ higher, but its still will be affordable
    i wanted $50, but it looks like $75.
    Question, is USB even inportant here? its not buss powered, so u still need power, i could save a good amount of $$ if i made it RS232, and not usb
    ofcourse u need to have a rs232 port on the carputer, and im sure they are all taxed out... so maybe USB is better for carputers
    remember im not a carputer guy, so i need your advice
    thanks
    mitch
  3. #43
    Jul 2004
    Orlando
    Well initially to keep costs down and allow developers quicker time to get the programming up and running, I would say release the RS232 setup.
    Also after some of these have been tested and the bugs (if any) worked out, then maybe a USB version might be feasible.
    Most people here know where to get an RS232 to USB adapter if no serial port is available.
    My 2 cents....
    Just getting started...
    Alpine CDA-7995, Toshiba 5205-S503, Lilliput 7" Touchscreen
  4. #44
    MySQL Error
    Oct 2004
    rs232 makes this real easy....
    usb makes this nice
    i think usb is a better interface, i got tons of usb ports on my pc, but 1 rs232
    i even got a USB to 4 port rs232
    i need to make a decision on this
    need more feedback
    with rs232 i could be at $50
    usb $75
    with rs232 i would prob make you use some sort of custom cable
    mitch
  5. #45
    Aug 2004
    ATL
    With the RS232 to USB adapter being only $5 off ebay i would say save the $25 and make it RS232. No reason to spend the extra money. But i def want one.
  6. #46
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Asides from USB->Serial Adapters being cheap, there's also the fact that making your board RS232 will very likely allow any Sirius software to control your board (without having to add usb support)... this can be benetitial on the long run when/if many applications are available to control sirius connect devices..
    Ride Runner RR's Myspace
  7. #47
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Not to mention all the problems with stand-by and hibernation and USB devices, much safer going with RS-232
    肚子笑痛了
    S60 Install
  8. #48
    Jul 2004
    Orlando
    so far RS-232....
  9. #49
    MySQL Error
    Oct 2004
    ok, now
    say we go rs232
    let me see what i come up with...
    playing with design now
    mitch
  10. #50
    Jul 2004
    Orlando
    great!!
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  3. fried USB ports
    By alti in forum General Hardware Discussion
    Last Post: 07-10-2005, 12:27 AM
  4. USB Interface System
    By Mrbmw99 in forum Hardware Development
    Last Post: 07-08-2005, 01:14 PM
  5. USB Soundcard Woes
    By phc in forum General Hardware Discussion
    Last Post: 02-11-2004, 06:02 PM
