There is a small, 5 pin header on the sblive that you can hook up momentary switches to to control the volume. Lemme go find some more info.
http://mp3box.2y.net
How would I go about making a hardware volume control? I'm using a SB Live and all four channels. Before the sound get inputed to the amp I need a hardware volume control. I want to make one knob controling all four channels volume. Is there a POT that contols for items? How do I use the POT, ie which wire goes where? What type of POT do I need. I want to be able to mount the knob in-dash or console. Any suggestion?
ODYSSEY
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
I'm planning on doing this for my next project, so I dug up a little more info. I took a couple of pictures of my SBLive:
http://mp3box.2y.net/temp/livevol1.jpg
http://mp3box.2y.net/temp/livevol2.jpg
I belive a switch between the top and the bottom would be volume up, and a switch between the middle and bottom would be volume down.
Hope this helps you.
That is a good idea. But what if your system/sound card happens to lock-up? I want something that not depentant on the computer. Any suggestions?
ODYSSEY
ODYSSEY
(\__/)
(")_(")
use a poteniometer (it is basically a variable resistor)... wire it so that it has an input and output and u can just connect it between your existing wires with out cutting them
I just have volume control built in to hot keys on my touchpad...
Any type of poteniometer? Do I need 1K, 10K?I was thinking about using 4 like the one below. Then just stacking the four on top of each other and put a rod in the hole.
ODYSSEY
(\__/)
(")_(")
chek out Tehota's thread...... he has added volume switches to his Passat.
go with the 10k... and i like the stacking idea
im staying away from the soundblaster live and going with a hercules 5.1 with upfront bay contols and rear rca ouputs, i beleive they make a model with hardware volume built into the bay, i just have to see if it controls the front bay outputs or the rca rear outputs.
<p align="center"><a href="http://www.mobilemediacentral.com"><img border="0" src="http://www.mobilemediacentral.com/images/logos/mmclogo.jpg" width="171" height="151"></a></p>
