Results 1 to 6 of 6
Thread: CCTV Camera
    Apr 2005
    Queens, New York
    CCTV Camera
    I am going to be installing a CCTV camera in my car for Rear View. Im going to hook it up to my Xenarc 700TSV. And the power will be hooked up to my Reverse Lights so it auto-switches on. Now basically that is the easy part. I want to be able to hit a switch or something while i am driving and still have access to view the camera. I dont want to have to be in reverse just to view the camera. Is there any way i can do this?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Trick the camera into thinking you're in reverse?
    Apr 2005
    Queens, New York
    Yeah. Basically If i wanted to have the camera power on(so the xenarc would autoswitch), while i am driving. I just want to flip a switch if i am driving then the xenarc switches to AV2. But still have it hooked up to reverse.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Newbie astral's Avatar
    Jul 2003
    Minnesota
    assuming your monitor will support this auto switching to second source when provided, it would be a simple task of wiring a switch and a diode up. the switch would provide power as an alternative to the reverse lights providing power. you would need a diode to prevent your reverse lights from comming on when you flip just the switch.
    Power = RED
    Video cable = BLUE
    This is your life and it's ending one minute at a time...
    Constant Bitrate craniumdesigns's Avatar
    Apr 2005
    Hayward, CA
    so a diode basically just allows power to go one way? in this case power can go thru the diode FROM the reverse lights, but not from the switch TO the reverse lights? is that how they work?
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Quote Originally Posted by craniumdesigns
    on the nose
  1. Reverse camera query: USB webcam or mini "spy" camera?
    By SamDude in forum General Hardware Discussion
    Last Post: 07-13-2007, 02:10 PM
  2. [REVIEW] In-Bumper Rear-view camera
    By RoyN in forum General Hardware Discussion
    Last Post: 12-30-2006, 03:42 PM
  3. How do I setup TV / Camera Support ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:42 AM
  4. why is my backup camera not working with my capture card?
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-17-2005, 03:52 PM
  5. For Sale, 1 x Wireless Miniature Security Camera.
    By buildfromscratc in forum Classified Archive
    Last Post: 07-15-2004, 07:13 PM
