that is the way I ran mine for a long time...with old telephone wire...then I got a shutdown controller and disconnected the power button. Should work fine for you.
OK SO i mounted a momentary push button in my dadh today. And i am going to connect it to the Green and white wire from the PSU to the mobo. My question is, I am usiing 24 gauge telephone wire. It comes in a roll and its NOT the telephone wire with the plug on the end. This wire had 4 THINK wires inside a black/red/green/yellow wires. IM just wondering if it is ok to take to of the wires and connect them to the PUS to mobo wires? I already tapped in to the wires and rad the wire to the switch. I just didnt connect it to the switch. Will this work? Hopefully i didnt waste my time....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
1997 VW Jetta GLX VR6
old HP MP
PIII 600 or so 256 MB
7" Xenarc
and some plywood holding it all together
My Project
OK Great im just hoping its not to think of a wire!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Sorry i ment *thin
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
It wasnt for me...it really isn't gonna take a real load. Just think about how small the wire is going from the switch to the board in the first place. Only trouble I ran into was it was a pain in the *** soldiering it in place. another option if you want is to use old network (cat5) cable. I use that for a bunch of stuff in my setup, LED's etc. It is a bit bigger...but the phone wire should work.
Glad I could be of help.
old HP MP
7" Xenarc
My Project
i used 24guage speaker wire for my power button only because i didn't want to run a cat5 cable and not use but 2 of the wires
well as long as it will work. Basically I took the wire and tapped into the Green and white wire and that wire is coming out of the casr about 2 feet. I am going to connect the to wires to a 2-terminal barrier strip. Then the wires from the button will connect to the other side of the barrier strip.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
I used CAT5 but telephone wire should be fine. I needed 4 pairs for running power LED, Reset LED, power button, and reset button.
i was gonna do the leds and all but then i got ready to run the wires and decided i didn't want to mess with wiring the leds
yeah i used cat5 for my switch for my inverter it should be fine for switches/ leds
