Results 1 to 10 of 18
Thread: USB2.0 hub don't go full speed in XP
    Dec 2004
    Sweden
    Why is my new USB2.0 hub not identified as a 2.0 device? XP says this unit can go faster.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    What do you have plugged into it? If you have 1.1 and 2.0 devices plugged into it, the hub reverts back to 1.1 speeds. If you don't have anything plugged into it yet, I would think that you may need some service packs or drivers.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Dec 2004
    Sweden
    I have a 2.0 DVD drive into it and the damn thing won't even open the tray so I guess the hub is not working very good.
    Dec 2004
    Sweden
    I have now tried with a USB2.0 flash mem with same result. This unit can go faster...
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Gredd
    Is the Hub plugged directly into the computer port, or do you have a cable that is between the hub and the computer. What about a canle between the 2.0 DVD drive, and the Hub. The cable might not be 2.0 compliant. If it is not, then the hub will see a 1.1 device, and then the computer will tell you that you could be doin 2.0 instead of 1.1.
    As for the USB DVD not being able to opne, USB 2.0 has nothing to do with the power available at the port. It is possible the DVD isn't opening because the DVD needs external power. Not opening doesn't sound like a 2.0 versus 1.1 problem. It sounds like a power problem.
    Michael
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Same result as what. Have you checked for updated/installed drivers?
    Michael
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    What are the specifics of the OS and the computer?? it could be either software or hardware, or both!
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Do you have SP1 (Service Pack 1) or SP2 installed?
    Dec 2004
    Sweden
    Thanks for helping!
    SP2 is installed. The DVD-drive works as it should if I plug it in directly to the computer. It opens the tray without external power.
    The cable from computer to hub is what I got with the hub so it SHOULD be compatible with 2.0 when the hub says USB2.0 all over.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Thanks for helping!
    You got it with the Hub, or "it came with" the hub. It may not be compliant. Also, your DVD issue is a power issue. LET ME SAY IT AGAIN, THE DVD ISN'T WORKING CORRECT BECAUSE OF POWER. Remember that the longer a thin wire is, the morevoltage and amperage loss. Since there is a long cable, and it is very thin, and that long cable supplies 4 ports in your hub from one port on your computer, you are gonna have power problems.
    Michael
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  3. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 08:39 PM
  4. Can I upgrade XP home to prefoessional?
    By Skipjacks in forum Software & Software Development
    Last Post: 01-30-2005, 09:06 AM
  5. Replies: 4
    Last Post: 01-29-2005, 07:35 PM
