Results 1 to 10 of 12
Thread: custom lexan or plexi case
    Jul 2005
    Calgary
    Ok, the plans for Carputer II are coming together... except maybe a better name needed... anyhoo I'm finding the hardest part is figuring out what to do about the case. too bad there isn't a very basic cheap case that fits mini-itx board, a PCI card, and an opus 150w.
    I think the custom cases showed off on these forums are actually pretty cool tho, and want to do the same. I'm good with the software, and not bad with the hardware, but not sure where to start with building a case. I've searched like crazy and there are lots of shots of cases in various stages of fabrication but it would be great if someone could post some diagrams/dimensions etc they used for a simple case. I'll probably cut a couple holes for fans (like the guy w/ the 97 tacoma) and pop an LED (or 2 or 3...) in. Anyone out there able to jot down a few dimensions of the pieces and how they were fitted so I don't chew threw 5 sheets of plastic to get it right?
    99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
    97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
    currently: installing (finally!)
    Dec 2004
    Orlando, FL
    here's one i drew up and built...
    I dont know how to upload images, and im not sure if its going to work. but in the image i mixed up the thinkness on the glass and the aluminum. the glass is 1/8th and the aluminum is 1/16. you have to find someone that can weld it, but its pretty sturdy
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Build one out of 1/4" wood paneling first, make sure you get your dimensions right, then build it again out of plexi. And have the place you buy it from cut it, cause it's a PITA. I nearly lost a finger.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    is it possible that using plexiglass for the case can cause interference with a gps device. The reason i ask is i built a case cause it was too hot in the trunk for my carputer and i needed it in the cabin. Now my gps mouse isnt as effective at picking up sats. My car alarm is also acting as if there is some sort of interference.
    Jun 2000
    Nashville
    There is no EMI shielding effect with plexiglass. If you didnt move the GPS, I can't see a reason why you are now having trouble locking to sats, other than maybe now your power and signal cables are crossed (this plagued me for months). Your car alarm might have some interference because of the lack of EMI shielding on your carputer. How close is it to your alarm brain?
    I'M DEBT FREE!!
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by wizardPC
    ~ 5 feet. And no the gps has not been moved. When the computer was in the trunk i got 10 sats easily.. now if i'm lucky i have 6 . When you say power n signal cables do you mean in the usb? My case isnt put together very well (small L brackets and some duck tape for support). Could there be an EMI leak causing the prob? I'm gonna redo my case as soon as i go to home depot (where i'm gonna have them cut it and use thicker plexi)
    Jul 2005
    Calgary
    good tips and thx for the diagrams stillydipstix! was that for a mini-itx or ?
    I assume you drilled slim leader holes then screwed the whole assembly together... what size holes and what size screws did/would you use?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Sonicxtacy02
    It's most likely a power issue. You moved the computer, and I assume you had to add a USB extension cable. The increased distance, mixed with the very thin wire in the cable, is having a detrimental affect on the GPS.
    Oh, and just to be sure, nothing else has changed, right? No new tint, didn't move the GPS even a couple of inches, nothing, right?
    Michael
    Dec 2004
    Orlando, FL
    Quote Originally Posted by jagsnag
    I took the aluminum brackets that i bought from home depot and had them welded for if i remember correctly it came to $50. and i cut a hole in the back of the box(where the lid is connected) for the connection to the mother board. and i used a silicone sealent to glue the plexi into place.
    sorry my wording and typing sucks, im tired.
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by Wiredwrx
    Michael
    actually i removed an extension cord for power and one usb extension. The problem is still there. And its kinda random too... half the time i'll start iguidance n have 0/12 sats, then the other have i'll start n have 5/12 right away. The gps wasnt moved. No tint. The wires are all run down the same side of the car. I would think that i'd have more signal strength cause the usb isnt run the length of the car anymore. Its gotta be some kinda interference. When the computer was in the trunk it was without a case but no with a case the interference is worse. Could it be static from the plexi??? Sorry for the threadjack btw lol
  1. Creating custom case from....and old case!
    By Peoples in forum Fabrication
    Last Post: 06-14-2005, 11:40 PM
  2. Custom Case
    By CustomZ02 in forum Fabrication
    Last Post: 01-18-2005, 10:20 PM
  3. Need A Custom Metal Case?
    By brentp4 in forum General Hardware Discussion
    Last Post: 11-12-2001, 09:19 PM
  4. Making a custom case..............??
    By brandondere in forum General MP3Car Discussion
    Last Post: 01-11-2001, 07:17 AM
  5. some pictures of my car and custom case
    By Awol][ in forum General MP3Car Discussion
    Last Post: 12-07-2000, 08:04 AM
