Page 6 of 6 FirstFirst 123456
Results 51 to 56 of 56
Thread: HOW TO TURN ON LAPTOP IF YOU CANT REACH BUTTON any input device that can turn it on?
  1. #51
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Quote Originally Posted by lwells
    That's quite neat.
    I have a Toshiba Tecra 8100 which unfortunately has the power button on the side of the laptop, so it isn't replicated on the dock. Does anyone have suggestions on how I can get it to power on/off with the car without hacking up the computer?
    You could try wake-on-ring, or wake-on-lan. Thats depends on your BIOS though. As for the hacking, its really not that difficult, as long as you know what you are doing with a soldering iron.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  2. #52
    Jun 2004
    Quote Originally Posted by kiltjim
    The reason I don't want to hack the laptop itself -- I don't mind mutilating a docking station -- is I want the ability to remove the laptop from the car to use as a... err.. laptop
    So I guess WOL/WOR might be an idea and then have the profile set to hibernate the computer when power is removed (i.e. ignition off)... Hmmm.
  3. #53
    Feb 2004
    PA, USA
    Then do what I did, hack the laptop, and put in a connector that allows you to pull it out. I used a headphone jack, and the matching plug. Someone else used the existing modem jack (a much better idea) since they never used it.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  4. #54
    Jun 2004
    Is this preferably to a WOL/WOR system? (By the way, someone mentioned it doesn't work with XP: is this the case?). Any advantages/disadvantages to either?
  5. #55
    Feb 2004
    PA, USA
    Well, the WOR/WOL methods require that your laptop support it (mine doesn't). Also, you need to be able to send the right command, and I really didn't care to figure that out. With the external button method, it is identical electrically to pushing the button on the laptop. If done correctly, it works like a charm. You just gotta watch what you are doing, since you are soldering to the laptop.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  6. #56
    Oct 2004
    NY
    theres also an option that consists of a mechanical device.... I done a panasonic toughbook & it had a right side slide back switch....I had a door lock actuator & had it pull a cable that went to the switch.....it worked fine... trunk/door popper solinoids can be used
    on a push button if all else fails, you could use a small electric plunger to actuate the switch remotely.....
    it's usually best to solder right to it, but if all else fails, or in certain situations this can be done easily enough...
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 04:53 AM
  2. Replies: 9
    Last Post: 12-09-2004, 12:34 AM
  3. Replies: 3
    Last Post: 08-20-2004, 08:42 AM
  4. Anyone figure out how to turn on laptop?
    By RTman in forum General Hardware Discussion
    Last Post: 08-10-2000, 08:19 AM
