Results 1 to 10 of 13
Thread: 12v at 33amp survicing crank?
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Hey everyone, I have a quick question. How does one make a regulator that can survive cranking? :-P Basic, right?
    Basically, I'm trying to think of a way for people with inverters to survive crank, minus a new battery. If there's a way to make a quick and dirty circuit that can survive crank and supply 12v, let me know. I don't need 33 amps, but that's what my 400 watt inverter wants.
    I imagine some type of regulator? A bunch of them in parallel I imagine making a PCB that has room to add more of these circuits, so you can increase the power ratings.
    BTW: It doesn't need to be a filtered12v, just 12v.
    Fusion Brain Creator
    Mar 2005
    itll never work with just regulators, I suggest you look intostep up circuits
    put it this way: if thre was a way to make a wuick and dirty circuit to do what you propose, itd be done by now
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    why would people with inverters need a regulator?
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Mar 2005
    Sorry, I didn't know of the type of circuit to "step-up". Just because it isn't done yet, doesn't mean it can't be done. I mean - it's a custom circuit, so it would have to be made by yourself. Anyone with that kind of knowledge would be making a sproggy, or other.
    That or no-one though of messing with the voltage going into a inverter.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by KyleYankan
    I don't get this. 12 volts X 33 amps = 396 watts but that doesn't mean that your inverter "wants" 33 amps. It depends on the circuit load. If your computer only draws 200 watts, then you inverter will only "want" 16 amps. No load, no amperage required.
    Want to:
    Mar 2005
    pudge: not a regulator: just something to keep the 12v during crank.
    BTW: http://www.xs4all.nl/~odu/dcdc.html
    6v to 12v, at 1a sustained.
    My Inverter needs to output 1.5a at 120v, for my PC to work.
    Assuming my inverter is 90% efficiency:
    1.5 * 120 = 180 watts
    180 watts at 90 effiencecy: 200 watts
    200 watts needs to hop into my inverter.
    200/12v = 16.6 amps.
    Seems doable. I mean, I can order up to 5 samles of the step-up chip at a time. That means in a week or two, I can have 15/20 of the chips. Then the rest of the components seem trivial in price/sample. Make a bunch of these circuits and run them in parallel. It means you can run your computer even on a 6v battery.
    Mar 2005
    Quote Originally Posted by Bugbyte
    I know,my computer is only 180 watts actually, but I wanted to be able to fully use my inverter. At least, plan to use it. I'll probably end up with an extra battery for crank. My system survives crank right now, but Ithink that's because I have a battery that's like 2 months old. Has anyone played aorund with the bank of batteries in the back of a hybird? *heads to junkyard*
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    why not just a small SLA with a diode?
    2 Kicker Comp 10"
    Check it out?!
    Mar 2005
    Diode? Would that work? I thought you had to use a battery isolator? Like a relay?
    I imagine a diode that would let the main battery charge the SLA, and the PC hooked up to the SLA?
    Additionally: What's a good high-wattage didoe good for this? anyone know?
    Mar 2005
    4you cant run step ups in parallel
  1. M1-ATX and heavy 12V rail
    By miki in forum Power Supplies
    Last Post: 05-13-2005, 07:18 AM
  2. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 12:47 AM
  3. Replies: 5
    Last Post: 05-26-2004, 12:55 AM
  4. OPUS surviving crank
    By Ricky327 in forum Power Supplies
    Last Post: 11-27-2003, 04:20 AM
  5. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 12:33 PM
