Results 1 to 5 of 5
Thread: How do i "soft" power off my MII board?
    Oct 2004
    I'm trying to determine if my PSU is bad (doesn't shut down when i turn car off)
    so i wanna try and manually shut the PC off via "soft touch" method.
    To my understanding, the only thing that affects this is in the BIOS (if you have it set to "instant-off")
    So theoretically, if when the PC is on and running... if i jump the pwr switch ... it should shut down correct?
    And the fact that I'm running an nlited OS now shouldn't affect anything?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    just jumper the power switch for a second and it should soft off. I just use a metal nail to do it lol.
    Oct 2004
    haha.... yea i was using a swiss army knife to turn it on when i was using it in my room...
    okay so.... if when i do this and it doesn't shut it off? Do i have a bios problem? Or a OS problem?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    are you sure that you are touching the right jumpers?
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Oct 2004
    yea I need to go home and double check that i'm touching the right jumpers... its a tiny little spot with little light... but I was pretty sure i was...
    its how i turned the computer on several times throughout my nlite "trial and error" experiment.
    The guys at minibox also just told me that my M1 in "dumb mode" (no jumper settings) will NOT send a shutdown pulse to my mobo... is that true?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. Darn ITPS! Need power help!
    By DJ-FrosT in forum Power Supplies
    Last Post: 07-16-2005, 07:40 PM
  3. Replies: 4
    Last Post: 05-04-2005, 11:24 AM
  4. Epia vs. Regular Motherboard
    By jnusaira in forum Newbie
    Last Post: 02-09-2004, 08:49 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 05:27 PM
