Results 1 to 7 of 7
Thread: Gigabyte's i-RAM review at anandtech
    Nov 2004
    Cali
    Yes, I know there are two threads on this topic, but since I helped originate the threads and they are now buried, I am starting a new thread.
    Here is the linky
    http://www.anandtech.com/storage/showdoc.aspx?i=2480
    For the lazy people out there, i-RAM is Gigabyte's gadget that plugs into PCI slot for power and uses SATA-150 pretending to be a hard drive while in reality using 4 sticks of RAM for up to 4 Gigabytes of memory.
    Summary:
    - expensive
    - it IS faster in just about everything (<10 second boot for fresh unoptimized windows install)
    - it is not dramatically faster for the most part
    - limited size (4GB)
    - still some bugs do work out in the whole execution
    - very limited numbers for now (1000), but apparently another iteration is coming up with more memory slots.
    I have found you an argument; I am not obliged to find you an understanding.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Interesting. I use to have something simular to this years ago. It wasn't used for storage, even though I made a ramdisk out of part of it. It was mostly use for system ram. I had four of them, each one held 4 MEGS of edo ram. I had a 286 -12 with 16megs of ram running windows 3.1. Pretty cool for a 286.
    I could see how this could be interesting for a car-puter. Really need to keep up with the backups, I would be afraid that battery would run down and lose everything.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    This looks awesome! I'm guessing that the 10 second boot time is w/o POST. Someone would have to write a program that would automatically backup the ramdisk everytime the car is turned on. I think that a 1gb ramdisk would work for almost everyone.
    Nov 2004
    Cali
    Quote Originally Posted by 0l33l
    Not sure if you caught that in the article, as long as the power supply is still connected, even if the computer itself is off, the i-RAM will continue taking in power.... so the program would probably need to take into account the difference between computer being turned off and the power supply being turned off.
    and yeah, i think its not including the POST, the boot time for the same setup on 74Gig raptor was 15 seconds.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by rushnrockt
    I read the article. Not all PSUs supply constant 3.3v. Like I do'nt think that inverter powered installs can supply that. And what would happen if you went on a 3 day trip somewere? Say bye bye to your data
    Someone's gotta get this and test out the total boot times. I wonder what the time out of standby will be
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    just thinking out loud here ... you could always have a partition on your hd with a program such as nero ghost and the image of the ramdisk on there.
    ramdisk looses power -> boot from secondary device (HD) -> windows up and running -> restore partition for next boot
    This would only cause your boot time to be very long (as it is now) when you loose power
    I'm seriously contemplating this as an option to get decen boot times from my carputer (hibernation is a no go here)
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Standby time shouldn't change, since standby keeps main memory alive and doesn't involve disk access. Hibernation times should improve, but you have to ask yourself what's the point? Hibernation moves RAM data to disk so you can cut power, but with this the "disk" is more RAM that's still consuming power. You might as well just go standby without the expensive hardware.
    I'm not saying the i-RAM is useless; it's very good if you want fast clean boots. Just not useful for standby/hibernation.
  1. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 08:39 PM
  2. FS lots of ram
    By kderedwolf in forum Classified Archive
    Last Post: 04-29-2005, 07:28 PM
  3. REALLLY noobie question on RAM
    By tdevil in forum Newbie
    Last Post: 02-01-2005, 03:45 PM
  4. Fs: Ram, 160gb Sata Hd, Ibm Laptop
    By StratusPh34r in forum Classified Archive
    Last Post: 12-09-2004, 05:41 PM
  5. upgrading ram on comp
    By cubanmoses in forum General Hardware Discussion
    Last Post: 07-28-2003, 03:53 AM
