Sorry, but that inaccurate. Its a common misconception that higher flow rates mean less cooling. Besides, don't thermostats in cars just control the cooling fan to come on/off?Originally Posted by BADDERICK
When you have a closed loop watercooling system, car or pc, the water passes heat to the radiator to be disapated. If you double the flow rate, the water only spends half the amount of time in the radiator, but cycles through the rad twice which gives the same cooling performace. Hard to explain, but if you imagine a car on a race track that laps at a steady speed of 1lap per 60secs. It passes down the straight every lap, which takes say 20secs. If the car doubles its speed, it does the straight in 10secs, but for every 60secs its now doing 2 laps so spends the same amount of time on the straight.
LinkBack URL
About LinkBacks
